Diggs24
- de plains! de plains!
- 2015 GTI
https://www.golfmk7.com/forums/inde...c-damper-from-the-audi-a3-saloon-2013.369369/Can you share more? What exactly is it and where do i get it?
Oh, that thing. Still not sold.
Add me to the list of ppl who swapped the 034 Upper and Lower insert to the Powerflex hybrid. I've had the 034 inserts for ~8k mi.
They were pretty good at first. With only mild vibration/resonance when accelerating at low speeds (I'm DSG). After a few thousand miles though, engine movement starting coming back and aggressive downshifts would buck the car. I think the billet inserts starting wearing out the stock rubber bushing, as they weren't bent when I took them out.
The Hybrid puck not only controls engine movement better, it has less NVH at low speeds. There's definitely more vibration in reverse, when in park at an incline, and with AC on. This is exactly the same kind of NVH I had when I installed a poly rear motor mount in my Si. It will probably settle down quite a bit after it breaks in.
Definitely would recommend the Hybrid puck. Should have went this direction from the beginning.
I think because the GTI scene is more price conscious? But then again these mounts are all the same for the MQB cars so maybe APR will do something for the mk8/8y.
got my hybrid on order as well!
I have a fair amount of vibration, not enough to rattle the keys or the steering column, but I can feel it if I put my feet on the floor. It has been in for about a month.I wanna revive this for a minute. For those who have had the hybrid for a good while, and with the stock arm, what kinds of vibrations are you getting? And to what extent?
Im almost 2 years into the set of 034 inserts that I’m happy with, but I am getting increased vibrations traveling up the steering column that I don’t like. They’re mild until I’m off the clutch, but they cause my keys to rattle and make driving occasionally annoying.
With the hype that the hybrid gets I’m expecting it to be significantly better.
Installed in March of last year.Wow. How long was it installed?
