daconchslop
- SC
- ACS SE/Tech
VAG
Hahahahhahahahahaha
After talking with GTI Jake, I had installed BFI Stage 1 motor mount and BFI Stage 1 trans mount insert. I have used them with a PowerFlex hybrid lower puck with a Roc-Euro bar and with a OEM dogbone. With the OE bar vibration was very low but still there a little in Drive and reverse with the AC on. It was even less with the R-E bar but in the back of my mind I could not forget the story about the transmission case damage reported. I just installed an ECS Tuning dogbone. This combination of BFI mounts, PF Hybrid and ECS dogbone is beyond amazing. There is no vibration in drive. In reverse it is barely perceivable if at all. AC-on or AC-off makes zero difference. This is with a brand new PF Hybrid and ECS dogbone. Once I get a few miles on this set-up, I fully expect to have a totally OEM-like NVH. I have had the BFI mounts for a couple months now and they have settled in beautifully, just like Jake assured me. The motor and trans feel very planted. Throttle feel is great and there is none of the rocking motion that plagues the stock set-up.
Fitting the ECS Dogbone required a couple very simple mods to the hybrid and its metal insert sleeve. The PF Hybrid's metal insert is very slightly too wide to fit between the side bars of the ECS dogbone. A couple passes on opposite sides of the insert with a file produced small flats that let the insert slip into place. These same ECS dogbone side bars also have a cross-brace running between them that the OEM dogbone does not. I had to trim a small piece off the end of each of the 2 poly ribs that sit inside the dogbone's channel because they hit the dogbone's cross-brace and prevented the dogbone from sliding all the way in. Both mods were very minor and have no effect on the function of either hybrid mount or the dogbone.
I used the 3 new bolts supplied by ECS and torqued to OE specs including the full 90* follow-up angle. After tightening the 3 bolts, I torqued the dogbones cross-bolt to 65 ft-lb per ECS's instructions.
I was expecting some NVH but was in shock when there was none. I was willing to compromise some NVH to not use the R-E bar. With the BFI mounts and PF hybrid I was and could have remained quite satisfied with the low NVH I had. However, I already had an ECS dogbone I bought a couple months ago and never used so I decided to try it. So glad I did. I feel like I have had to give up nothing NVH-wise to get much better motor/transmission control. Nothing except money, that is. LOL.
But don't most people recommend staying with the stock pendulum arm?BFI engine and tranny mounts
PF hybrid puck
ECS pendulum arm
is how I read it.
I understand that but want to know if you recommend staying with the stock pendulum arm?People recommend a lot of things. I'm just stating what he has on the car because it's a bit confusing with the terminology.
Knowing your power level I guess that speaks well of the stock pendulum arm.Can't because I've never had anything but stock.
Only thing you got wrong is the ECS Dogbone is their pendulum arm. He replaced the roc-euro pendulum arm with ECS pendulum arm.To clarify because I'm somehow lost after reading this - you're running a Poweflex hybrid lower (complete lower replacement), BFI stage 1 engine mount/stage 1 transmission mount insert (inserted into the OEM transmission mount), ECS' dogbone (as in their insert, not their pendulum mount?) and the OEM pendulum mount (you removed RocEuro's piece of shit?). Is that accurate?
Sorry of the confusion.To clarify because I'm somehow lost after reading this - you're running a Poweflex hybrid lower (complete lower replacement), BFI stage 1 engine mount/stage 1 transmission mount insert (inserted into the OEM transmission mount), ECS' dogbone (as in their insert, not their pendulum mount?) and the OEM pendulum mount (you removed RocEuro's piece of shit?). Is that accurate?
