ECS shows the 5QM-129-635 inlet as fitting only the 1.8T and non-R 2.0 turbo:
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/adapter/5qm129635/
If you select the Golf R it says this part does NOT fit your vehicle...
Additionally ETKA shows not only different part numbers but very different dimensions for the two inlet o-rings, because the inlets have different diameters, at least at the o-ring...
I transferred the CTS piece from my is20 to the 38 when I swapped them keeping the same o ring. So is mine not correct? They were both a pita to get seated fwiw
