Anyone here wanna sell me their stock Golf R (not GTI) inlet pipe?
I think I’ve seen you post before that the golf R and GTIs use different inlet pipes, but when I look online I see the same part number for both. Can you post a source that shows different part numbers for the turbo inlet?
Thanks!
Sure,
Golf R:
https://www.vwpartsvortex.com/auto-...2-0l-l4-gas-engine/engine-cat/air-intake-scat
GTI (same inlet and o-ring part numbers as the 1.8T):
At $48 for both the IS38 inlet and o-ring, I'll be buying it for my IS38 swap unless someone has a cheap used one they want to sell...
Yet, at the Golf R link you provided...
Sent from my SM-G955U using Tapatalk
Odd... The GTI part cost twice as much and the part number is the same with the exception of “-L” at the end of the R’s elbow. Both ECSTuning.com and shopdap.com show the GTI and R having the same part.
I would hope you could return it if they end up being identical. If you end up getting one, please keep us posted.
ECS shows the 5QM-129-635 inlet as fitting only the 1.8T and non-R 2.0 turbo:
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/adapter/5qm129635/
If you select the Golf R it says this part does NOT fit your vehicle...
Additionally ETKA shows not only different part numbers but very different dimensions for the two inlet o-rings, because the inlets have different diameters, at least at the o-ring...
So they say. Size doesn't matter, it's how you us itAnd the thing is...they are all exactly the same size at the intake side and at the turbo side. So it's how they get there that matters. APR is the only one I know of that gradually tapers from one end to the other. CTS and the others have a very abrupt transition at the turbo end. I'm not a fan of APR by any means, but I do like this piece.
And remember brothers, just put the TIP in. Lol
Go APR or go home on this part. Unitronic has an equivalent piece coming out.
Sent from my LG-H910 using Tapatalk
FWIW, the only thing our piece shares in common is that they're both Turbo Inlet Elbows. Aside from that, it's not equivalent in any way, shape, or form.
More details to come upon full release.
