Engineer90
- NJ
You need to find a suspension shop. Otherwise you'll just keep throwing money at the car without a resolution.
They're extremely difficult to find, most are general mechanics
Not yet as I am more confused now
Yesterday I took it to my mechanic, we lifted the car, looked underneath, spun the tires and nothing seems out of place. Did a tire rotation and the vibration is still there so that crosses off my new wheels from the list of suspects
I am more confused though, because yesterday me and my mechanic drove the car... he's a heavy guy. Since the car had a heavy load on the right side, the vibration wasn't there... so I am going back to my first theory that my front passenger strut is shot. He's not sure what it could be either. So I'm at 50/50, either the bearing or strut
This, very much.You need to find a suspension shop. Otherwise you'll just keep throwing money at the car without a resolution.
Yep, he was going to make me put out $300 for a single OEM bearing, without taking a single look at the car. No, thanks. Gonna find a good susp.shop and have them check on the quality of his shocks/springs installation he did back in October. My current problem is not due to that, but would be good to know how things are down there regardless.That guy sounds like a d**k hole
My mechanic is cool, he has a small shop with 3 lifts. Plus, speaking Spanish with him and showing him I know wtf I'm talking about cars helps.
I am starting to think I'll just get new Bilstein B8s, ball joints, and bearings. I hate that my GTI, a car that I love, is driving like it's a 150k mile 15 year old car depressing.
Did the vibration start after the install of the wheels? If so I'll take hubcentric rings for $500, Alex!
Doubt that's it. I got them rotated yesterday and still the same issue.
The pinpoint vibration on braking started 10k mi after getting tuned. Then chassis vibration increased when cruising, then steering wheel vibration intensified. Now i feel grinding vibrations when cruising even on good pavement. I hear what sounds like bearing noise in relatively sharp and fast turns. From all of my amateur diagnosis it appears the bearings are indeed shot. Considering 60k mi over bad roads around here, it sounds like a sound (lol) diagnosis. But regardless, a visit to a good suspension shop is in the cards for me. I love the car, keeping it for 4 more years, i want it to ride well.I have a slight vibration and rhythmic hum going through gas and brake pedals as well at speed.
If a wheel bearing is actually going out you will know it very clearly. If it's very slight don't even worry about it. One of the first symptoms in a tuned car other than sounds and vibrations is a sudden increase in torque steer in a fwd car that has almost none (mk7) to begin with. If it starts really pulling wheel hard to the left, put car up on jacks, then have a friend spin axles as fast as they can and listen for loose bearing ball thingys . Works better with wheels off.
If all the rings are the wrong size or have a problem, rotation is not going to do any good.
Did the vibration start after the new wheels?
Where are you in NJ? I'm sure many people here can chime in with suspension shop recommendations.It started before the new wheels, but wasn't as strong. I hit the front-passenger side 2-3 times since we got some snow and craters were left in the streets after the plows. I thought I bent the wheel again, but I brushed it off since I was gonna get the new wheels. Now mind you, the 225/40/18 that come stock with the Austins are stiffer than the 245/45/17 I got now. I suspect the oscillation is more pronounced because the side wall is taller. I also feel somewhat more of a dip from the front-passenger side when braking hard. This is why I suspect it could be the ball bearing, strut, or wheel bearing/hub.
That being said, I could get new hub centric rings, that wouldn't hurt. Any recommendations?
Don't keep throwing money at this until you know what the problem is. If your hubcentric rings fit properly then there is no reason to replace them.
I'm in the Newark area, so you can imagine roads over here are like the craters on the moon.
The rings seem to fit properly, so we'll see.
Do a google search for "speed shops". Searching for "suspension shops" gets you truck repair places.I'm in the Newark area, so you can imagine roads over here are like the craters on the moon.
