Hi DV52, what is this tweak you speak of ? Where are you publishing? I'd like to have my cluster on at all times, rather than needing the lights on.
thedoc46: Hi . My tweak is just something that I've been working-on for the last month-or, so. After much experimentation I think that I now have a reasonable understanding of how "Leuchte programming" works on MQB platform vehicles. So I have turned my attention to instrument cluster lighting. My preliminary observations suggests that it's all done with a set of 80 channels with the words "dimming_characteristic_curve_adjustment" in their description.
Long story short, based on my findings I managed to develop a new "dimming_curve" for the photo-transistor that lives inside the instrument cluster. The job of the photo transistor is to modulate the dash lights (including the discover media/pro screen) depending on cabin illumination (i.e. daylight/night-time levels). Using my new dimming curve values for what's called the "X" numbers, the instrument cluster in my car now illuminates during daylight hours without the rotary light switch being turned-on.
I can also illuminate the dash at night (without the light switch-on) by changing what's called the "Y" numbers. But after trying this and driving at twilight, I have chosen to keep the default "Y" numbers. What happened when I had the dash illuminated at twilight was that I lost the important signal telling me to turn my main car lights-on. So I elected to retain the safety message-but at the price of not illuminating the dash at night. But you may have a different view - nothing wrong with that!
Anyhow, my VCDS tweak goes something like this (see full explanation on VWW):
Instrument Cluster Illumination - during daylight (without rotary light switch turned-on)
VCDS tweak Instructions
- Have the engine running and start the Ross Tech software (I found this to be necessary to successfully change the adaptation channel settings on my 103TSI - my13 model. Else I kept getting "out-of-range" error messages)
- Select 17 - Instrument control module
- Select Security Access - 16 from the "Open Controller" screen
- Enter the magic number 20103 and return to the "Open Controller" screen
- Select Adaptation - 10 from the "Open Controller" screen
- From the pull-down button change the 5 x adaptation channels shown in the table below to the New Settings as indicated:
Notes:
- The setting for "X1" does not need to be changed - I have included it in the table for completeness
- When entering the new hexadecimal values, take care to use the exact structure shown in the table (i.e. enter all leading zeros and enter a space as shown - it is not necessary to use capital letters for the alpha characters).
- If "out-of-range" error messages appear, try starting the change sequence in the reverse order- that is, commence by changing X5 and then change the channels with reducing X numbers.
- EDIT: I've received feedback from a VWW forum member (thanks Mikey1) advising that he did not need to have the engine running (in step 1 above) to change the adaptation channel settings on his Golf R.
Postscript:
After implementing this tweak, you may observe that the infotainment screen is brighter. If this happens, the lighting intensity of the infotainment screen can be adjusted as follows:
- Press the MENU button (thanks Mikey1) on the bottom RHS of the discover media/pro escutcheon plate
- using the RH dial on the infotainment unit (or your finger), scroll to the SETUP icon - which looks like a gear-cog and it's on the extreme RHS of the option list
- press the panel that says Screen
- press the panel that says Brightness
- Select either Brightest, Brighter, Medium, Darker, Darkest option
- Exit all screens
See Pictorial instructions below
Lastly, I fully anticipate that the lighting effects that result from this tweak will not be to every one's liking. If this is the case, please revert ALL settings to their default value (as shown in the table), or use my paper and the related spreadsheet to create your own dimming curves.
Cheers
Don
