Is there anything in the settings for language?Hello!
I need your help.
I have a device:
Part number:
3QOO35844
Installed software train version:
MST2_US_VW_P0504D
Instelled software MU version:
0613
Software version:
H25.14.78_STD2Plus_NAR
Cars from the US and I'm interested in the question:
1. Is it possible with the help of a SD card to replace the firmware with the same but for Europe.
I found a lot of firmware, but none of them fit. (MST2_US_VW_P0635D_MU0757, MST2_EU_VW_P0891D_MU0891)
The purpose of this is to change the language of the menu (it would be great to have a native Ukrainian).
Simply put - replacing the firmware with an identical one but for a different region!
I have no complaints about the work of the system. There are minor glitches in the work of Androidauto, but it is not important and tolerable.
Thank you!
@Chillout
@simaservis1108
There are only 3 languages:Is there anything in the settings for language?
Do you have Dynaudio or Fender?Hi.
Require some help if anyone could, uk based.
I have a Golf Mk7 R
With MIB 2.
Recently the infotainment has been glitching. The sound volumes/settings seem to jump around sporadically.
I can get in the car today and it will be fine. Then later on today I could get in turn ignition on and mid or treble or even bass has jumped right up, or dropped to 0. Sometimes even the fader would have jumped the sound to the passenger side or all over the drivers side.
I don't have vw warranty so can't take it to a dealer to see if there's an update and/or get it replaced.
Is there a software update I can do?
also found a page - Vagupdate. Which can give a firmware download at $80 but not sure if this would be an answer.
any help appreciated.
thanks
Chris
Device number: 3G0035020E
Hardware: H51
Software: 0814
I have dynaudio system.Do you have Dynaudio or Fender?
I've replaced the amplifier with an aftermarket dsp/amplifier as the dynaudio wasn't to my taste. Aswell as new speakers and sub.I think the amplifier is on its way out.It stores the equalizer settings.
I can also update both the firmware and the maps.Hi @Chillout
Hoping you can help. I have a 2016 GTI Autobahn with the MIB2 system. Looking for a Software update / map update if available. Called the VW dealer in Denver and they said they will charge $150 to perform the update.
Attached is what the car is currently running. Any assistance would be greatly appreciated!
Thanks!
