Update MIB2 Software and Maps?
RenatoZG
Croatia
VW Golf mk7 2.0 tdi
Hi..
Where i can found firmware/software update for discover media on pics ? 😁
taras.kocuk
Lviv
Golf 7 Sportwagen
Hello!
I need your help.
I have a device:
Part number:
3QOO35844
Installed software train version:
MST2_US_VW_P0504D
Instelled software MU version:
0613
Software version:
H25.14.78_STD2Plus_NAR
Cars from the US and I'm interested in the question:
1. Is it possible with the help of a SD card to replace the firmware with the same but for Europe.
I found a lot of firmware, but none of them fit. (MST2_US_VW_P0635D_MU0757, MST2_EU_VW_P0891D_MU0891)
The purpose of this is to change the language of the menu (it would be great to have a native Ukrainian).
Simply put - replacing the firmware with an identical one but for a different region!
I have no complaints about the work of the system. There are minor glitches in the work of Androidauto, but it is not important and tolerable.
Thank you!
@Chillout
@simaservis1108
Ken60
Kent UK
2016 Golf Cabriolet
Chillout if you would not mind offering me any advice ..... Just bought a 16 Reg Golf Cabriolet with the non SatNav version of the MIB2 . When I check the info it says
Device No 5K7035200E
Hardware H22
Software 0245
Media Codec 2101.0.0.10
At the moment bluetooth is not working and neither are Android Apps or Voice. VW in Kent want £250 to allow ( code) Android Carplay and are going to look at the bluetooth. Any point upgrading the firmware for this unit or will they do this when the enable Apps.
Hello!
I need your help.
I have a device:
Part number:
3QOO35844
MST2_US_VW_P0504D
0613
Software version:
Thank you!
@Chillout
@simaservis1108
Is there anything in the settings for language?
Galin
Ecuador
VW T-Cross
Hi! I need your advice please...
I recently bought a VW T-Cross 2020 (Assembled in Brazil). The info is:
Part number: 5G0035280C
Hardware: 558
Software: 5532
I want to know which is the MIB version for this device?. It is possible to update the firmware of this unit?
Thanks in advance! ;)
Galo.
Chrispydubs
Truro
Golf mk7 R
Hi.
Require some help if anyone could, uk based.
I have a Golf Mk7 R
With MIB 2.
Recently the infotainment has been glitching. The sound volumes/settings seem to jump around sporadically.
I can get in the car today and it will be fine. Then later on today I could get in turn ignition on and mid or treble or even bass has jumped right up, or dropped to 0. Sometimes even the fader would have jumped the sound to the passenger side or all over the drivers side.
I don't have vw warranty so can't take it to a dealer to see if there's an update and/or get it replaced.
Is there a software update I can do?
also found a page - Vagupdate. Which can give a firmware download at $80 but not sure if this would be an answer.
any help appreciated.
thanks
Chris
Device number: 3G0035020E
Hardware: H51
Software: 0814
simaservis1108
Serbia,Belgrade
Seat Leon 5F FR
Hi.
I have a Golf Mk7 R
With MIB 2.
thanks
Chris
Hardware: H51
Software: 0814
Do you have Dynaudio or Fender?
Chrispydubs
Truro
Golf mk7 R
I think the amplifier is on its way out.It stores the equalizer settings.
I've replaced the amplifier with an aftermarket dsp/amplifier as the dynaudio wasn't to my taste. Aswell as new speakers and sub.
Had my regular audio installer do the work. And has worked for several weeks before starting to go glitchy.
Have been reading on owners club and forums that the MIB2 unit is quite glitchy anyway. Prior to the audio install the unit occasionally was on without sound coming out and would need to be turned off and on again etc.
We are trying to rule out whether its the headunit and or software. As a new or upgraded unit is around £1200.
Is there any software update that I could use that is newer than the 0814?
Willing to pay for an update file....
sonicdeth
Colorado USA
2016 GTI Autobahn
Hi @Chillout
Hoping you can help. I have a 2016 GTI Autobahn with the MIB2 system. Looking for a Software update / map update if available. Called the VW dealer in Denver and they said they will charge $150 to perform the update.
Attached is what the car is currently running. Any assistance would be greatly appreciated!
Thanks!
KevinC
'19 Golf R, '21 M2c
^^ Why do you think you need a software update? My '16 ran that exact same hardware & software version and it was flawless. My advice: if it ain't broke, don't fix it.
A map update, that's a different story. Definitely could use an update there. You might try reaching out to Peter (@peterdna) via Instagram - he sells current maps with the hokey protection removed so that they will run in any MIB unit.
simaservis1108
Serbia,Belgrade
Seat Leon 5F FR
Hi @Chillout
Thanks!
I can also update both the firmware and the maps.
If you are interested PM me.
mm8718
UK
Scirocco R Line 2017
Hi all..new user here and just bought an RLine 2017 Scirocco UK spec (TDI).
Lovely car but I suspect the software is out of date. I updated the maps to latest version but I can't seem to find anything for my infotainment. I believe I have the MIB2 Std EU version and like a previous poster I came across vag update site where they charge a small fee for the files.
I have already paid the fee to the dealer to activate Carplay and that works fine. I am just concerned the update might remove the AA and Carplay activation.
Everything works and sounds fantastic so I am also trying to understand what the benefits of the upgrade may be?
If you can help me with the install files without having to go via vag update...even better!
I attached some pics of my current version
