billbadass
- your moms house
hello team! I have an EQT tuned 480whp mk7 with lots of goodies. Bought it stock at 30k miles and it has been turned up as a commuter weapon for ~70k amazing miles now as the car has nearly 100k miles on it today and the car has been remarkably hassle free at this power level and easily one of my favorite cars I've ever owned including lots of different fancy sports cars.
I got a 034 rear sway bar with superpro end links back near 35k miles and to be honest it has been an ongoing hassle. I am about to remove the entire setup and looking for something that will be no hassle forever but with similar stiffness to an 034 rsb set to max stiffness.
Granted I live in a land of pot holes but originally the 034 setup broke the welded bolt spots off the subframe from increased stiffness, eventually got titanium bolts which could be cranked down harder, and repaired the subframe, then the 034 bushings wore out surprisingly fast and caused clunks and had to be replaced twice, then the bushings in the superpro end links broke and fell apart after about 10k miles, and then I went back to Moog end links which would only fit the 034 rsb at the soft setting, which I prefer the max stiff setting much more.
Now i have yet again some other clunk in the rear from the sway bar because of god knows what, and so I am about to remove it all entirely, light it all on fire in my neighbors front yard, and replace it all with something that is same stiffness as 034 set to max stiff but will last forever. I do not care about the cost within reason because am so frustrated.
I know this has been covered endless times, but for those of you with lots of miles on your RSB setup, what do you all recommend for a very stiff rear sway bar with end links that will last forever?
