I finally got to test my hood vent at VIR last Thursday:
First log was from the tail end of the first session of the day (I ran in afternoon only, this was ~1:30pm for reference). I had a bit of traffic in the first half of the session, but this snapshot of data is taken from 20 to 23 minutes into a 25 minute session. I never let off of pushing the car (even though it was slow AF due to the ridiculous heat) and 277F oil temp (actual, on the dash) was the highest I could force it to go.
I WAS having issues with excessive timing pull (which will generate more heat) due to sucking oil from the PCV (detailed in my build thread here:
https://golfmk7.com/forums/index.ph...-edition-hpde-shenanigans.401435/post-7983702 ) which may affect it in some way.
Because I had always previously driven with the engine cover ON, I left it on for this first session as a baseline:
I fought issues with the EPC light cutting power and excessiving ignition pull again in the second session, and the third session my EPC light was on but no (overly noticeable) power loss so I made another effort to test without the engine cover on. I had issues with the logger losing connection over curbs, but this is a 200 second snip taken from the end of the 25 min session:
The car was WAY slowed down from the power being pulled, as evidenced by the lower average speed but higher TPS %.
Temperatures across the board were all just a hair lower, while the ambient a hair higher with engine cover off vs on. Probably within noise of driving consistency, etc.
Honestly I was hoping for better cooling results from the hood vent, BUT I still think it's overall a success considering this was in
~20F hotter ambient temps than I'd logged before. Combined with the EPC/knock retard issues I was having, I
think there's a chance that if I can get my PCV issue sorted, temps should be overall lower next time without these problems, even if it's just a bit. Coolant temps MIN seen on track was ~16F higher than prior, coolant temp MAX about 3F hotter than prior, and coolant temp AVG was about 10F higher than before in cooler temps.
IF anyone will be at Fastivus at Summit Point on September 30th, let me know and I'll loan you a dongle to help log this stuff and add to it!
