SierraCarrera
- Ohio
- MK7 Sport, 981 CS
Thank you!! Ordered a A0 dongle and downloaded Simos since I have Android, should have some track data in a few weeks.
100% man, no fucking way I'd bother. It's such a PITA.people are logging with obd11 on track? i can't imagine sitting there in grid hoping it pairs in time to get all of the params added in to log at 4hz.
Welp it arrived today (way sooner than expected!), wasn't initially showing up on my bluetooth so went through Arduino IDE and got that flipped on and it's now showing up but it won't connect to Simos. Looks like I might have to flash it with new firmwareAwesome! Shoot me a PM when it arrives and I'll help you get set up with logging if needed.
I'm also working on slightly reworking the data model in the background - Won't really be changing how the individual "cards" of data for each vehicle sample appear... but trying to make it so it's possible to make quick comparisons between samples, or manage different filters for drawing overall conclusions better.
Thanks, seems to be something weird happening when I try to flash the ISOTP BLE Bridge firmware onto it. I asked in the Facebook group maybe I can provide some logs to someone.Make sure you permitted location services when you installed Simos Tools.
Otherwise this is a good thread to reference for general info:
https://www.golfmk7.com/forums/index.php?threads/ecu-logging-capability.420890/
Got it working, where can I get one of those sweet, sweet CSVs?Make sure you permitted location services when you installed Simos Tools.
Got it all working, went for a quick drive around the block - https://datazap.me/u/sierracarrera/test?log=0&data=1-2-3-5-7-14 Will have some data from Mid-Ohio to share after Labor Day, hopefully this heat wave dies off by then....
Mid-Ohio data! Will send you the whole run soon - https://datazap.me/u/sierracarrera/moscc1?log=0&data=4-24https://drive.google.com/file/d/1A_Jkvcih97weNskYWfeCjBikq_Le7o7e/view?usp=sharing
Try downloading that CSV and logging it with it. Will log the MDI oil temp on the dash (which is accurate, vs the default modeled oil temp) plus the coolant outlet temp which I'm also trying to gather data on now.
Cool nearly won it!Data added for @reverend_sean and @SierraCarrera !
Full report here: https://www.datadrivenmqb.com/drivetrain/coolingdata
Reverend_sean - our second FMIC sample for reference
SierraCarrera:
And while this isn't in the published report, I've got some other pages that are interactive to use for toggling different filters and highlighting different samples, but here's a screenshot of everything from coolest to hottest (using ECT max temps seen):
