JerseyDrew77
- Virginia & NC
- 2016 TR GTI S 6MT
yea.
That's too far down which is why you keep getting that CEL. You want it to where the sensor is almost flush, maybe poking a little, on the inside of the DP.
yea.
So i should rotate it out more from the DP?
Yes!
How many turns do you think? I will get my car up on a lift later this week since i have a few other odds and ends to get installed.
get a real tune
I don't have any codes scanning with vcds for o2 sensor. I had perpetual P0240 with JB4. Nothing changed on my DP setup when I went Tomioka+Eurodyne.
Question for you guys:
I've been going through the tuning process with full bolt ons using an IE DP and an open spacer. I asked the tuner not to disable the cat codes so I could try to get it to pass emissions using the spacer later on. All throughout the process, I've had slow to respond and stuck lean codes (which I hear can also be an air leak from a loose fitting), and just figured I'd mess with it when the tune was done. I recently finished the tune and had the cel still, as expected, for a couple hundred miles, then it just went away. I checked the AP and all channels show ready and there are no codes. I'm glad I didn't have to do anything, but it just seems odd. Anyone else run into something like this?
