Stumbling start (intermittently, so that's fun [still not fixed, apparently])?
avenali312
Mableton, GA
2015 GTI
I am at about 52k but it's a 9yr old car. Just little bit of oil residue on the timing cover, not that bad.
Mine has apparently been seeping like this for a while based on how much buildup there was on the hose going to the TIP. I'm a bit above 74k miles and it's a 2015, so coming up on nine years old in the next few months.
avenali312
Mableton, GA
2015 GTI
The knock on wood did not help me here haha.
This happened pretty severely again today. Below is the series of events.
  1. Drove about 15 minutes to drop our dog off at camp for the day. Shut off car.
  2. Got in car maybe two minutes later and started without issue.
  3. Drove another 15 minutes to a lab appointment. Shut off car.
  4. Gave up my three vials of blood and went to start the car about 10 minutes later.
  5. Car just cranked and cranked (did you know it will crank on its own even if you're not pushing the key forward? weird). No start.
  6. Try again. Cranked and cranked for a while before finally turning over and stumbling its way up to idle RPM.
  7. Car ran perfectly fine the rest of the 20 minute commute to work.
Ran a quick scan when I got the office and found the below. The misfires are new and there doesn't appear to be anything fuel/evap related in there like last time.
Code:
OBDeleven data log
Date: 2024-03-21 09:20
    Car: Volkswagen Golf GTI
    Year: 2015
    Body type: 5-dr hatchback
    Engine: CXCA
    Mileage: 121486 KM
01 Engine
    System description: 2.0l R4 TFSI
    Software number: 5G0906259A
    Software version: 0006
    Hardware number: 06K907425B
    Hardware version: H13
    ODX name: EV_ECM20TFS0205G0906259A
    ODX version: 001008
    Long coding: 091D00124424002F0000
    Trouble codes:
        P030100 - Cyl.1 Misfire Detected
            static
        P030400 - Cyl.4 Misfire Detected
            static
        P030000 - Random/Multiple Cylinder Misfire Detected
            static
02 Transmission
    System description: DQ250-6F MQB
    Software number: 0D9300041T
    Software version: 4511
    Hardware number: 02E927770AQ
    Hardware version: H53
    Serial number: TFK01503230338
    ODX name: EV_TCMDQ250021
    ODX version: 001001
    Long coding: 0014
    Trouble codes:
        P173400 - Starter release from the selector lever sensor system
            Intermittent
03 Brakes
    System description: ESC
    Software number: 3Q0907379P
    Software version: 0385
    Hardware number: 3Q0907379C
    Hardware version: H32
    Serial number: 51185000002057
    ODX name: EV_Brake1UDSContiMK100ESP
    ODX version: 034033
    Long coding: 01FA6BA134290974007D020281C82980D62C9000408194B400430050C006
    Trouble codes:
        No trouble codes found
08 Air Conditioning
    System description: AC Manuell
    Software number: 5GM907426A
    Software version: 1001
    Hardware number: 5GM907426A
    Hardware version: H02
    ODX name: EV_ACManueBHBVW37X
    ODX version: 003019
    Long coding: 00020004200100000000000000000000
    Trouble codes:
09 Central Electrics
    System description: BCM PQ37BOSCH
    Software number: 5Q0937087R
    Software version: 0145
    Hardware number: 5Q0937087R
    Hardware version: 028
    Serial number: 86580904151260
    ODX name: EV_BodyContrModul1UDSBosc
    ODX version: 014004
    Long coding: 00001A464041A04969E44000001407201000000000000000000000000000
    Subsystems:
        System description: WWS    150403
        Software version: 0581
        Hardware version: 043
        Serial number:         150525080038
        Long coding: 0E4DDD
    Trouble codes:
        B1806F0 - Heated seat passenger's side Safety shutdon due to occupant detection
            Intermittent
15 Airbag
    System description: AirbagVW20
    Software number: 5Q0959655T
    Software version: 0825
    Hardware number: 5Q0959655T
    Hardware version: 009
    Serial number: 003MHM02B6WT
    ODX name: EV_AirbaVW20SMEVW37X
    ODX version: 002138
    Long coding: 8CCCFC00000000005000001AC24800000065
    Subsystems:
        System description: BF-Gewichtss.
        Software version: 0021
        Hardware version: H11
        Serial number: IBH0000J150002RWO10S
        Long coding: 30305A
        System description: SideSensor_Df
        Software version: 0887
        Hardware version: 001
        Serial number: 3570000000014295F31C
        Long coding: 2D2D2D
        System description: SideSensor_Pf
        Serial number: 3580000000047881E31J
        Long coding: 2D2D2D
        System description: SideSensor_Dr
        Software version: 6149
        Serial number: 3510002B71A14CA2707/
        Long coding: 2D2D2D
        System description: SideSensor_Pr
        Serial number: 3520002A31A8785331F0
        Long coding: 2D2D2D
        System description: FrontSensor_D
        Serial number: 3550002BB19EFF53640N
        Long coding: 2D2D2D
        System description: FrontSensor_P
        Serial number: 3560002A519EFF55830K
        Long coding: 2D2D2D
    Trouble codes:
16 Steering Column
    System description: Lenks.Modul
    Software number: 5Q0953521P
    Software version: 0175
    Hardware number: 5Q0953569A
    Hardware version: 075
    Serial number: 20150327401076
    ODX name: EV_SMLSVALEOMQB
    ODX version: 001015
    Long coding: 0410
    Trouble codes:
17 Dashboard
    System description: KOMBI
    Software number: 5G1920856
    Software version: 4270
    Hardware number: 5G1920856
    Hardware version: 342
    ODX name: EV_DashBoardVDDMQBAB
    ODX version: 009037
    Long coding: 07BD090A2980CF0502086A001000000000000000
    Trouble codes:
19 Gateway
    System description: GW MQB High
    Software number: 5Q0907530AC
    Software version: 2203
    Hardware number: 5Q0907530M
    Hardware version: 212
    Serial number: 29041510002122
    ODX name: EV_GatewConti
    ODX version: 011020
    Long coding: 0101000820085900EF00002A1C0F00000001050000000000000000000000
    Subsystems:
        System description: E221__MFL-DC1
        Software version: 0101
        Hardware version: H10
        Serial number: 29150000768150075173
        Long coding: 31FFFF
    Trouble codes:
42 Driver Door
    System description: TSG FS
    Software number: 5Q0959593B
    Software version: 0025
    Hardware number: 5Q0959593B
    Hardware version: 020
    Serial number: 18051506050FCT
    ODX name: EV_DCUDriveSideEWMAXKLO
    ODX version: 006003
    Long coding: 003E03200000040000000000
    Subsystems:
        System description: Fond FHSG DRV
        Software version: 0002
        Hardware version: 007
        Serial number: 00000000000001184479
        Long coding: 011000
    Trouble codes:
44 Steering Assistance
    System description: EPS_MQB_ZFLS
    Software number: 3Q0909144H
    Software version: 5061
    Hardware number: 3Q0909144H
    Hardware version: 505
    ODX name: EV_SteerAssisMQB
    ODX version: 012140
    Long coding: 8102
    Trouble codes:
52 Passenger Door
    System description: TSG BFS
    Software number: 5Q0959592B
    Hardware number: 5Q0959592B
    Serial number: 120515060507SE
    ODX name: EV_DCUPasseSideEWMAXKLO
    ODX version: 006003
    Long coding: 003E03200C00040000000000
    Subsystems:
        System description: Fond FHSG PSG
        Serial number: 00000000000001186198
        Long coding: 091000
    Trouble codes:
55 Headlight Regulation
    System description: AFS-ECU
    Software number: 7P6907357D
    Software version: 0090
    Hardware number: 7P6907357A
    Hardware version: H07
    Serial number: --------------
    ODX name: EV_HeadlRegulVWAFSMQB
    ODX version: 001120
    Long coding: 021801010B000400
    Subsystems:
        System description: LeiMo links
        Software version: 0004
        Hardware version: H01
        Long coding: 2E0000
        System description: LeiMo rechts
        Long coding: 2E0000
    Trouble codes:
5F Multimedia
    System description: MU-S-S-US
    Software number: 5G0035844
    Software version: 0655
    Hardware number: 5G0035844
    Hardware version: 014
    Serial number: V7B01604152375
    ODX name: EV_MUStd4CPASE
    ODX version: 002040
    Long coding: 02730000FF00000021220001001800001F0203040100010002
    Subsystems:
        System description: ABT_Std_Plus
        Software version: 0030
        Hardware version: H60
        Serial number: VWZ8Z9RS501QPP
    Trouble codes:
        B11CF53 - Tuner for satellite radio Deactivated
            static
75 Telematics
    System description: OCULowMQBUS
    Software number: 5QE035285A
    Software version: 0564
    Hardware number: 5QE035285A
    ODX name: EV_OCULowMQB
    ODX version: 001003
    Long coding: 02730002C2821A017F1E06000000
    Trouble codes:
        U111100 - Function limitation due to missing message
            Intermittent
A9 Structure Borne Sound
    System description: SAS-GEN 2
    Software number: 5G0907159
    Software version: 0014
    Hardware number: 4H0907159A
    Hardware version: H06
    Serial number: 150320201417
    ODX name: EV_SoundActuaGen2AU64X
    ODX version: 003010
    Trouble codes:
avenali312
Mableton, GA
2015 GTI
Super easy. You don't even need to take the fuel lines off as once you unbolt and lift up off the catch you can shake it right there in the wheel well. The wiring and lines have enough slack to give it a good shake.
Is the consensus that ANY fuel in there means it's toast?
avenali312
Mableton, GA
2015 GTI
OceanJack
Bayonne
Mk7 GTI
I had issues with my LPFP failing intermittently, it would stumble when starting and randomly cutting out when just starting out to drive. Replaced the LPFP and that fixed my issue.
Then I had an issue with the charcoal canister failing, it wasn't full of fuel but I replaced the jet suction pump and N80 valve and PCV. Was still stumbling while driving in 4th gear, the AFRs would jump all over the place. Turns out the charcoal canister was bad, no gas in it but the charcoal was just rattling around.
Bought a used one from Autohaas for 100 bucks and been fine ever since.
avenali312
Mableton, GA
2015 GTI
Thanks for this. I'll definitely keep it in mind after my investigation haha.
I've had zero issues while driving though, which is odd to me.
OceanJack
Bayonne
Mk7 GTI
You can pick up a LPFP for about 125 bucks, I got mine from DAPAuto. Takes literally 15 minutes to replace.
@Diggs24 Helped me figure out my issues before, so I would also try his suggestion for pulling the charcoal canister as well.
avenali312
Mableton, GA
2015 GTI
@Diggs24 and/or @OceanJack
Think it is worth addressing the 1 and 4 misfire codes at all after checking the charcoal canister? Plugs are new about 15k miles ago. Coils have about 75k on them. Just not sure if the misfire codes could be popping due to a possible fueling issue. I guess I could always swap 2 and 3 for 1 and 4 to see if it persists first. My idle does seem to be just a bit rough and did recently have the valves cleaned, so it's not that.
