See you out there! Jealous that your commute won't be nearly as badFor those who are following my progress, I've updated my mods list on page 1 so you can see what I am showing up to the 2021 Solo Nationals with.
And your current camber/caster settings?I have enough camber that the front end gets a little squirrelly under really heavy braking. It's manageable, but also noticeable.
How close is the strut mount to the inside of the body? I was going to slot to add a little more but my camber plate is about to leave the flat part of the body
I don’t even think I can call it a commute, at about 50 min.See you out there! Jealous that your commute won't be nearly as bad
Rear is between -2.5 to -3. I have SPC rear uppers and the max is -3I have just around -5 f, -2 r
have not had issues with corner exit, but I'm a piggybacked 1.8 so not as much power as some. I haven't had brake issues but not racing fast courses either.
I'd like to try more up front but haven't figured out how yet. Plan to get more in the back but don't know what stock arms allow.
and the SPC is adjustable, correct?Rear is between -2.5 to -3. I have SPC rear uppers and the max is -3
Yes, adjusted to max.and the SPC is adjustable, correct?
@ my ride height, others may get more at a lower height.Rear is between -2.5 to -3. I have SPC rear uppers and the max is -3
I got an extra .5 with slotting and I'm going to try to get a little more.
On my setup, I'm going for -2.8.
How much slotting did you do to gain the -0.5deg camber?
I don't remember, but I'm planning on doing Koni install this weekend, so I can measure then.
I forget what caster is, camber is ~3.6 up frontAnd your current camber/caster settings?
