I have the RS3 bushings in mine, don't have any complaints. I don't believe you can run any caster or camber bushings on the LCA if you're also planning to run any sort of plates at the top of the strut. ST rules are pretty clear about either top or bottom of the strut adjustments, but not both. Edit: Reread the rules, offset bushings are allowed regardless of camber plates, I was thinking of adjustable control arms which are not allowed in tandem with camber plates
FWIW, I got the RS3 bushings from BFI and then bought replacement LCA from rockauto, cost about ~120 total for all the parts and I installed the new bushings in the LCA and then swapped them into my car when I did the suspension.
