2016 Mk7 R Estate just failed MOT as Rear Fog not working. Rear Fog Bulb OK (tested) and fitted a new headlight switch from VW, correct part number (MOT mechanic thought the headlight switch was the culprit).
When headlamp switch in the Rear Fog on position (pulled out) there is no dash light for rear fog and no light on the headlamp switch.
Fault code found with Carista =
Central electronics
Part #: 5Q0937086AK
Component: BCM PQ37BOSCH
Software version: 0162
ASAM/ODX identifier: EV_BodyContrModul1UDSBosc
Coding: 03501A66C24122F30BA44080B11C07281000000000000000000000000000 (hex)
Fault codes:
267022 Manufacturer-specific code
Can find no information about that fault code. Emailed Carista but no joy.
As far as I understand it the BCM controls the power to the rear fog light and there is no separate fuse for the rear fog. Everything else is working fine and there are no other fault codes.
The car has only done 19000 miles and is in as delivered condition with no modification. Any advice would be much appreciated. I have looked a lot for solutions on the web. Saw a report of someone being charged £600+ by VW to get this fixed! Nearest VW dealer 35 miles away so if I have overlooked a simple way to fix this I would be grateful for any help.
Central electronics
Part #: 5Q0937086AK
Fault codes:
