Don: that "virtual mk7" of yours looks extremely impressive! Thank you very much for the detailed analysis that you have done with it looking into my Rear Fog issue.
Yesterday I did try the "total vehicle reset" by removing both battery terminal connectors for 30 minutes. The anticipated bunch of errors re-set, most from turning the wheel lock to lock. The rest went away with the OBD eleven. However doing this made absolutely no difference to the problem with the Rear Fog.
I have just back-pinned terminal 5 of the Headlight switch with a T-pin (didn't pierce the wire) and done the DC Voltage checks that you advised. Results look essentially the same as yours.
I repeated the tests with the original Headlight switch and obtained the same results which confirms my suspicion that there was nothing wrong with it.
I have checked carefully in the passenger footwell (RHD) for any sign of water ingress and all looks good.
I agree that it seems unlikely that the problem is at the BCM end of the wire from pin 5 of the Headlight Switch given the nature of the 3 x multi-pin sockets and how firmly seated they are into the BCM housing with a low probability of moving. As you say the A29 wire is directly connected with no intervening terminals/plugs on-route to the rotary light switch. Looking at the wiring loom at the back of the Headlight Switch the wires are all wrapped together in protective black tape so it is difficult to believe that the pin 5 wire would have been singled out in isolation for abuse.
However I might need to check the signal is getting to the pin A29 end before the car goes to VW to minimise cost!
I wonder if VW have a way of reprogramming the BCM unit rather than just swapping it out for a new one (which sounds expensive).
- No fog-lights (centre turret in OFF position) = Rhythmic pulse fluctuating 2.3 - 2.8 V
- No Front fog-lights fitted to car so n/a (switch only has Rear Fog)
- Rear fog-light (centre turret out) = Rhythmic pulse fluctuating 0.1 - 0.2
