Diggs24
- de plains! de plains!
- 2015 GTI
Just go Eurodyne?
Please sir may I have anotherJust go Eurodyne?
Up top he's injecting for like 330-350* of crank rotation.... I don't know exactly when the exhaust valve is closing, but he is running 15* of ign advance. It's hard to imagine he isn't spraying fuel when the exhaust valve is open and getting very very close to the spark event. Very much so pushing the limits of the fuel system and I fear what's going to happen when the temps get in the 30s or whatever. Based on what I can see, either way probably too close to the limits for comfort for me personally. This kinda data shows me that MPI is definitely the way to go for straight E85 on IS38 even. Might be smarter overall to run E50 or so. My 2 cents anyways.
Wow, this is exactly why I post on here, this is extremely informative. So you're suspicions about injector pulse width have been confirmed. When I had the stock LPFP, I was having very similar issues to this. EQT told me that "the LPFP isn't keeping up and is dropping pressure to the HPFP." The datalogs showed the same events here along with fuel cuts, the logs looked very similar. I didn't notice anything strange about the HPFP. EQT at the time gave me 3 options...install MPI, install a larger LPFP, or pull back to E50 or E40. I chose to go with the LPFP. After installing the LPFP, the logs were showing the same fuel pressure losses and fuel cuts. EQT's exact response was "Ok, this is strange, can you please check your LPFP install and look at the venturi / o-ring on the pump in particular? You should be holding pressure for a lot longer than you are." After checking about 5 different times, I found the O-ring was forcing itself out of place, so that's when I made my first post and started zip-tying it into place. That's how I confirmed it was definitely lpfp issues.
I'm thinking EQT is just using their experience as to how far the 450 fuel pump can be pushed. Keep in mind, I'm not finished with tuning yet. I have a feeling that as long as my knock stays at 0, then I can pull back to E50 or 60 and they can keep winding me up. I don't know how much further though, what's max timing for full E85 IS38, lol?
Looking at my last log where I was getting a fuel cut at 6400rpms in 3rd, I really don't know if it's the same lpfp issue or if my fueling is just maxed out. All I can do is keep you guys updated and tell the next person trying to run full E85 to just go mpi and save a bunch of headaches.
Honestly for a E85 tune on stock turbo...your best option is using a dyno. Because you may hit MBT/peak power well before knock. And you could increase timing well beyond where you made peak power and actually start to lose power again. EQT I'm sure has the expertise to know where similar setup cars ended up timing wise, so they probably just go with that and call it good enough...nothing wrong with that at all. I bet E50 makes very similar power...
Can you post a log where you're getting this fuel cut? Just want to see it in a log. You threw out a bunch of links before and I got a little lost in what each one was trying to show etc. A 450 should not be close to running out of fuel on this setup, even without a PM4. Anyways yeah, please show me a log with a good fuel cut example you're talking about if you can.
On my second install, I removed that large plug connection and used heat shrink connectors to free up space inside the basket area. Also make sure when you compress the hat all the way nothing is being crushed.
