Navi
- BK/NYC/Hamptons
30 secondsI sure did. What's the time limit for adding a constructive comment?
How has the oil cooler been holding up? I'm looking to get the same kit from ebay. Found one thats abit more cheaper.Update time!
So engine is back together and running. Man it's nice to be driving my car again.
I went with the ebay cooler with the thought that it is only 190 bucks and if it does not work Ill just get the Racing line and call it a day.
The kit is 95% Katecool's kit having to do some cutting of the coolant hose to make it fit.
Kit comes with AN10 hose and what looks like good fittings. pressure checked both at 100psi. Flushed out the cooler and little amount of debris came out of it. All in all kit looks good.
Install is the same as Katecool, I wanted to mount the cooler different. I wanted it in the fog light location but the cooler being a 13row was too large to mount correctly.
Went with just using exhaust wrap ties to secure it to the crash bar. (picture later)
Performance, around town oil temp sits around 200f. Driving more at a steady speed 45mph+ around town would drop the temp to 185f, I have a oil thermostat that opens at 185, but is not really needed of you live where it does no get below 40f.
I am in the break in period of my new clutch so have yet to really put some heat into the engine but looking promising.
What's the difference between what you built and this kit other than a name brand oil coolerhttps://a.aliexpress.com/_mtPLJVd
I ordered this and built out my own custom setup with a Setrab cooler.
The one you posted removes the oil/coolant heat exchanger . Mine allows you to push the oil to the cooler through the oil filter location without having to remove that component.What's the difference between what you built and this kit other than a name brand oil cooler
Can I pm with some questions about this?Arrived today.
Let gravity do it’s just and open the oil fill cap.what are you going to do about oil filter changes? the oil is going to leak all over the top of the motor
What do you recommend I do?You’re in for a surprise. It’s going to make a huge mess. Only bc I had the same setup lol.
