^^^ use this tag before you past your data
ODBDeleven vehicle history log
Date: 2017-03-12 15:08
VIN: ######### (don't provide your VIN)
Car: Volkswagen Golf
Year: 2013
Engine: CHPA
Mileage: 27327 KM
Backup
Control unit: 03 Brakes
System description: ESC
Software number: 5Q0907379AC
Software version: 0437
Hardware number: 5Q0907379D
Hardware version: H75
Serial number:
ODX name: EV_Brake1UDSContiMK100IPB
ODX version: 008020
Backup name: ABS -Module: DV52
Long coding:
01FA8AA1202312700377060701C32980510448C0608094F3002A0028C1
Adaptations:
Tire pressure monitoring display:
Warning thresholds, tire pressure monitoring system:
2
Roller test bench mode:
Manual activation, possible
Running manufacturer number:
Status:
activated
Engine drag torque control:
activated
Activating and deactivating all development messages:
0
Counter steer support:
Strong
OFFROAD:
Offroad portion electronic differential lock:
0
Brake system vacuum pump:
Offset:
5
Hydraulic brake booster:
Offset:
8
Brake prefill:
Brake prefill:
activated
Braking torque boost for distance regulation:
3
Brake booster:
Brake booster:
4
Hydraulic brake assistant:
normal
Electronic Stability Program:
Speed-dependent activation:
Not activated
Brake disk drying:
Brake disk drying:
Weak
Hill-start assistant:
normal
Straight ahead brake stabilization:
activated
Brake pedal evaluation:
activated
Seat belt buckle scan:
activated
Dynamic starting assist:
early
Driver door status:
Driver door status:
activated
Automatic application during engine stalling:
activated
Starting vibration reduction:
normal
AUTO HOLD functionality:
Not activated
AUTO HOLD increase threshold, reduced tensioning force:
0 %
AUTO HOLD increase threshold, full tensioning force:
10 %
Developer_Function_1:
0
Monitoring of functional lights:
Indicator light in the button for electromech. parking brake:
7
Indicator light in AUTO HOLD button:
7
Vehicle and trailer stabilization:
Trailer information evaluation:
Not activated
Roller test bench mode, functional:
Not activated
AUTO HOLD slippage recognition:
activated
Overboost in brake system:
activated
Electromechanical parking brake, delay level:
6
Electromechanical parking brake:
Automatic application:
Not activated
Driver presence recognition via brake pedal:
Not activated
AUTO HOLD functional status:
Personalized settings:
Last setting
Tire pressure monitoring display, tire selection:
1
ABS in lower speed range:
activated
Thresholds for brake performance:
activated
XCP calibration protocol:
Not activated
Mileage: 27327 km
Date: 2017-03-12 15:07
