Ok so Jeff from HSTUNING wrote me back almost immediately but I missed his email because I sent it from a different account than usual. Here is his response to my questions about the NGK plugs. I think I'm going to give them a try.
Hi Matt,
I'll do what I can to answer your questions. It seems just a teeny tiny bit loaded, but that doesn't change my answers so:
(1) I can't tell you why no one else suggests them, but I can tell you why we do:
The traditional ground electrode configuration makes it easier for most DIY'ers to properly adjust and measure the gap. I'm not saying the Beru's can't be measured or adjusted, it's just not as simple for most. All else equal, that makes the NGK favorable. As a side note, we really promote the use of gap tools that provide consistent and easily measurable gaps like this:
https://www.summitracing.com/parts/aaf-all96515/overview/
Although the IKH24 is a good plug, it's longevity is not great in direct injection applications. The Beru RS7 is a good alternative but when an NGK plug in the correct heat range and configuration became available, it made sense to at least give it a chance. NGK does not quality tier their products, every single part that leaves their docks is a good as another. We respect them as a manufacturer for that. Because both RS7 plugs are sold as Audi parts, it's incredibly unlikely that quality tiering is an issue but it's worth noting. We don't blindly recommend NGK over Beru just because of this though. What really helps us is that beyond the Audi part number, NGK's part number allows us to decode the plug to make sure it's exactly what we want or need it to be. Because of the NGK part number we know that the plug is: double Iridium, NGK 8 heat range, specific resistor, etc. On the previous generation TSI engines, we were able to figure out that Volkswagen/Audi had specified a unique resistor on the stock plugs to prevent interference. Upon finding that, we were able to find a double platinum plug, identical to the stock plug in every way (including unique resistor) except for being one heat range colder than stock. Now lots of MK6 GTI, GLI, and Golf R owners have a reliable and long lasting plug to use with their increased output and temps. That information isn't as readily available from Beru.
We have done A LOT of ignition component testing in Gen 1,2, and 3 TSI engines. We did a write up to help the MK5/MK6/B7/B8 owners with spark plug choice. If you are interested, you can read it at
www.hstuning.com/blog. We didn't publish raw test results, but were able to make good recommendations based on what we'd found internally. During our testing, we found that the NGK plugs tend to be really flexible in terms of coping with thermal load. More so than Bosch or other brands we tested. So again, testing the new RS7 plug made sense. Our initial testing shows that this plug is going to be the same way. I log knock and watch it live on my AeroForce gauge, and haven't seen a hint so far with the NGK RS7's. To be fair, I didn't see a lot with the Beru RS7's, and most of what I saw was toward the end of my use with them.
The idle and cold idle is very stable with the NGK RS7, even with the gap reduced. I've logged raw knock voltage on the NGK's and the Beru plugs at room temperature and roughly 38 degrees F. Both plug sets were new, and the NGK had lower voltage on average. They were close, but the NGK's were slightly lower. I didn't expect much difference as the are interchangeable based on their application. I followed this test up with multiple wide open throttle misfire logs to make sure both plugs were at gaps that did not misfire at wide open throttle. This is very promising but not definitive. Things will shake out as the mileage racks up.
(2) I don't really know how to answer this question. We are very familiar with the factory parts catalogs and I was quoting an RS7 customer some parts one day and noticed that the NGK RS7 plugs had been added. It sounds like whatever system you are using is out of date. I've attached a screen shot of the factory parts catalog for you. You'll notice a note at the top explaining that the NGK and Beru parts are interchangeable so long as you use one brand or the other. My guess is that the Beru's will get phased out over time.
Thanks,
- Jeff
