NGK RS7 Plugs and other RS7 plug options thread
oddspyke
Middletown, DE
2016 GTI, 2018 ZL1
DAP has 4 for $57, HS Tuning about the same, modded Euros has them for $68 but with free shipping and I think they have coupon codes. There are plenty of other sites to check as well. It pays to get familiar with all the VW parts sites and shop around.
railroader
Yuma Arizona
Brisk er12s like 40 bucks on eBay. Just picked some up for my car
greypanter
Are there any benefits for using the RS7 coils with the RS7 plugs? or the oem coils are fine on stage 2 GTI.
Sent from my Pixel XL using Tapatalk
railroader
Yuma Arizona
Oem coils are fine
Sent from my SM-G950U1 using Tapatalk
Wrath And Tears
Azusa, CA
The most important thing with a tune is to run spark plugs one step colder (or possibly more depending on the tune, turbo, and amount of boost) to offset the increased heat in the cylinders due to more boost and increased timing. The proper gap helps prevent spark blow out under boost as well.
railroader
Yuma Arizona
What he said ^
Morphine
Lower Slobbovia
Credit to the following information is from Jeffrey Hurley at HS Tuning:
"We frequently get asked questions about spark plugs and ignition coils for MQB 2.0T cars, and I figured it might be helpful if I made a post to try to help mitigate confusion.
Current ignition coil revision: 06J 905 110 K
RS7 Plug, NGK version: 06K 905 601 M
Of course, both available at: www.hstuning.com
Of course, the whole idea behind not using the stock plug found in your GTI, Golf R, A3, or S3 is that with higher pressures and temperatures, we benefit from a plug that's one heat range colder than stock. The stock spark plugs are a (7) heat range in NGK nomenclature, and one heat range colder is (8). Until now, we've had limited options to do so, as our plugs have some unique geometry. Many have used the 079 905 626 G or 079 905 626 M RS7 plugs which were manufactured by Beru. Because NGK is the world leading manufacturer or plugs and we've not once had an issue with their plugs, we tend to prefer them. We also appreciate that NGK is fairly open with information about their plugs, allowing us to make sure we're doing what is right for our engines.
If you look at the first picture I posted below, you'll notice some differences between the Denso IKH24 plug and the NGK RS7 plug. One of the most obvious differences is the terminal of the plug, where it meets with ignition coil. The Gen 3 TSI's have a conical spring connection at the spark plug rather than the traditional ball seat male/female terminal found on the IKH24. This was done because it saves length, allowing for a longer ceramic insulator. The longer insulator improves flashover resistance and the terminal cup shields the contact. The Denso plug has ribbing to cope with flash over, where the cup design on the NGK is meant to prevent it.
You'll also notice notice that the center electrode and the nose of the insulator are shaped a little differently between the two. The RS7 plug is much closer in shape to the original plug for the Gen 3 engines, the 06K 905 601 D. I'm still looking into the Denso geometry and whether it's a benefit, detriment, or neither. I'll report back if I can find anything definitive. This geometry mostly has to do with thermal conductivity and the path for dissipation of heat. It's mostly important though, that the firing end of the plug stay under 800 degrees C.
The NGK RS7 plug is a double Iridium plug, which means that the center electrode has a laser welded Iridium tip and the ground electrode has a square shaped Iridium coating. That means, that the interval on this plug should be closer to 35,000 miles (the RS7 interval), than the 15,000 or so with the IKH24, making it more cost effective in the long term. This is also good news for you water/meth users as Iridium is the most corrosion resistant metal on the planet, and very stable when exposed to methanol.
With regard to the ignition coils, they have gone through several revisions since the cars were released. The latest is manufactured by Borg Warner, a name we generally trust in the automotive world (DSG owners can thank them for that technology). So far, I've installed them in our GTI and monitored: knock, ignition, AFR, and torque for changes, and the newest coils do seem to be a slight improvement on the slightly aged components that were in the engine, but we are currently working on a test bench to provide more information. We did this for the MK5/MK6 owners and things worked out quite well for end users.
Because we now have a good double Iridium option, I see no reason to depart from the original design simply to have a plug that's one heat range colder than stock. We now have a plug that's made with the original features, by the best plug manufacturer in the world, in the correct heat range. I've paired them with the new coils in our GTI and have been happy with the results. Hopefully this clears up some things for you guys. I'm happy to answer any questions I can.
I also put together an ignition service kit with the newest coil revision and NGK RS7 plugs in case any of you are looking to refresh your parts. I also put the RS7 plugs up individually and as a pack of four if you just need to get the colder plugs in your engine.
Have a great weekend guys/girls!"
I have been using the IKH24 for about 20000 km and decided to check them today.
So I let my engine cool down for a hour or so, then pulled the ignition coils out, the coils and boots came out in one piece no problem.
However the spring connections on 3 of the 4 stuck to the spark plugs…so I shoved the coil back in and wiggled and I got 2 out. The 3rd one is stuck on there, I cannot get it out without destroying it.
I would not recommend using the Denso IKH24 plugs as the differences in terminal design (as you pointed out) are probably what caused this.
They are also running too hot in my car. Eurodyne ST2, 93.
rafamonteiroo
Brazil
Hello friends, enjoying the subject,
Do ignition coils wear? My car already has 74000km, do you think I should change the coils for the RS3? Or use the stock ignition coils until the end of life?
WhyNotZoidberg?
Chi-Town
2017 GTI, 2015 TDI
rbwhite42
Orlando, FL
Beru Z345 Plugs
I just put in my second set of RS7 plugs: Beru Z345 14F-4NBPR2LS (079-905-626G) side fire plugs. The 1st set was in for 45,000 miles with no problems what so ever. Plugs looked in good shape when removed and probably could have gone another 15K miles.
Jovian
Sunnyvale, CA
2016 VW GTI
I got about 45k miles out of the Buru RS7 plugs 079-905-626G before they were replaced. Mine were not bad but due for replacing. Have had the new version 06K-905-601-M in my car for the last 12k miles and have been working well.
quailallstar
WOB DJ496
Ormond Beach, FL
MY19 MK7.5 GTI Bunny
Bump!
Anyone know where I can pick these up on the cheap? I paid $60 last go around for a set of 4, back in early 2020.
Audi RS7 plugs 06K-998-601-M
I've had these on my tuned 2019 MK7.5 (Stage 1.5 93 octane EQ Tuning) for about 38,000 miles now (car has 47k), and I've recently noticed a drastic drop in MPGs; roughly 2/3 MPG. Haven't pulled these to see what condition they are in, but my gut tells me this could be the issue?? Unless this is pure placebo and another issue rearing its head.
I drive a crap ton of miles (90% highway) a year - about 20,000 miles at this rate.
