I love the quality of the Blendmount. Just not a fan of the $150 price tag.I like that radar detector mount
Reminds me that I've had a hardwire kit for my R3, and a dash cam sitting in a drawer for my GTI for the past year haha
First time I've seen that dash cam brand, looks great. Does it allow for recording when the car is off to see if the tech is taking the car out for lunch?
Also, the duality of man;
I always shit my pants trying to figure out how to properly wash the engine bay. Did you disconnect the battery? Bag any extra parts or avoid certain parts with the pressure washer?
I just don't wash itI always shit my pants trying to figure out how to properly wash the engine bay. Did you disconnect the battery? Bag any extra parts or avoid certain parts with the pressure washer?
Cheers,
Try to avoid directly spraying the battery and alternator. The 40° tip on the pressure washer is fairly light pressure so it was fine.I always shit my pants trying to figure out how to properly wash the engine bay. Did you disconnect the battery? Bag any extra parts or avoid certain parts with the pressure washer?
Cheers,
Mk7.5 R’s all come with the H6 from the factory. The Mk7 had the H5 battery.From factory you (we) have an H5 size battery. Now you have an H6. The tray has bolt holes for the hold down to accept both.
Sometimes I've only seen certain batteries in H6. Other times I've seen the H5 and H6 of a given battery are so close in price doesn't make sense to go with the lower capacity H5.
Gotcha... I am confused about your battery though, I guess. You said it was the factory battery but also that the new H6 battery is bigger. So what size is/was your factory battery?Mk7.5 R’s all come with the H6 from the factory. The Mk7 had the H5 battery.
My factory was an H6 and so is the Odyssey. Odyssey batteries are known to be larger. Went from a 56Ah (EFB) to a 70Ah (AGM).Gotcha... I am confused about your battery though, I guess. You said it was the factory battery but also that the new H6 battery is bigger. So what size is/was your factory battery?
Not that it really makes a difference in any case. H6 works, H5 works. I've had both those sizes and a lithium in my TDI, a 2015 which came with H5. These days the toddler always wants to play in the car so H6 is in there now.
Part / Description | Part # | Qty |
Starter Bolts (Long) | N91037901 | 2 |
Shifter Bracket Bolts | N10106905 | 2 |
Ball joint nuts | N10332002 | 6 |
Drive Axle Bolts | N90991102 | 12 |
Drive Axle Bolt Retainers | 7L0407357B | 6 |
Axle-Hub Bolt | WHT005437A | 2 |
Driveshaft Heat Shield to Tcase | N91191701 | 1 |
Driveshaft Heat Shield (Triple Sqr) | N10644901 | 1 |
Fill Plug (Plastic) | 02M301241C | 1 |
Drain Plug (Trans) | N10037105 | 1 |
Triple Square TCase Bracket | N91000002 | 2 |
TCase Bracket Hex/Allen | N90956402 | 2 |
Front Driveshaft Bolts | N90846102 | 3 |
TCase Internal Bolt | 02J409359 | 1 |
TCase to Trans Bolts | N90990202 | 4 |
Upper Bell house Bolt w/ Stud | N90884602 | 1 |
Upper Bell house Bolt | N10721501 | 1 |
Pendulum Bolt | N91201001 | 1 |
Pendulum Bolt | N10699401 | 1 |
Pendulum Bolt | N91167101 | 1 |
Trans Bracket Bolts | N10706901 | 4 |
Lower Bell house Bolts | N10692701 | 1 |
Lower Bell house Bolts | N91060202 | 1 |
Lower Bell house Bolts | N90916102 | 2 |
Slave Cylinder Bolts | N90847002 | 3 |
Clutch Spline Grease | G000100 | 1 |
You didn't choose the Paul install optionApril 13, 2024 - 37,221 miles (WHITE)
All of the hardware for my clutch install just arrived from ShopDAP. I feel bad for whoever fulfilled this order...but they did a great job and everything was accounted for!
2018 Mk7.5 Golf R Clutch Install Hardware (Literally every bolt touched to do clutch job):
Part / Description Part # Qty Starter Bolts (Long) N91037901 2 Shifter Bracket Bolts N10106905 2 Ball joint nuts N10332002 6 Drive Axle Bolts N90991102 12 Drive Axle Bolt Retainers 7L0407357B 6 Axle-Hub Bolt WHT005437A 2 Driveshaft Heat Shield to Tcase N91191701 1 Driveshaft Heat Shield (Triple Sqr) N10644901 1 Fill Plug (Plastic) 02M301241C 1 Drain Plug (Trans) N10037105 1 Triple Square TCase Bracket N91000002 2 TCase Bracket Hex/Allen N90956402 2 Front Driveshaft Bolts N90846102 3 TCase Internal Bolt 02J409359 1 TCase to Trans Bolts N90990202 4 Upper Bell house Bolt w/ Stud N90884602 1 Upper Bell house Bolt N10721501 1 Pendulum Bolt N91201001 1 Pendulum Bolt N10699401 1 Pendulum Bolt N91167101 1 Trans Bracket Bolts N10706901 4 Lower Bell house Bolts N10692701 1 Lower Bell house Bolts N91060202 1 Lower Bell house Bolts N90916102 2 Slave Cylinder Bolts N90847002 3 Clutch Spline Grease G000100 1
FWIW, ShopDAP was the only website with all parts. ECS Tuning and FCP Euro all had some combination of parts that did not come up when I searched them. Total was about $180 shipped. This list doesn't include the flywheel bolts or pressure plate bolts since my Southbend Stage 3 Daily kit came with them.
