MQB_7.5R Build Thread
MQB_7.5R
Ohio
2018 Mk7.5 Golf R(s)
This is the build thread for my 2018 mk7.5 Golf R's. Follow my Instagram @MQB_7.5R for additional updates.
To get things started, I had a mk6 GTI as my first car. After learning how to drive stick, I started to modify the car. Four years later, the car was track ready with a Stratified ProTune. (Click Here for MK6 Build Thread) After feeling that I had reached the end of the GTI build, I started my search for a stock manual Golf R.
Here are some before and after pictures of the MK6 GTI.
Purchased: April 28, 2018 - 85,405 miles
Sold: July 26, 2022 - 99,216 miles
While searching for a stock Golf R, I stumbled upon an Oryx White manual 2018 Golf R in New Haven, Connecticut. I decided to make a 24-hour round trip to check the car out right before going back to college. The car was great and made the 12-hour drive home enjoyable.
Purchased: August 14, 2022- 35,405 miles
Cincinnati Museum Center: April 8, 2023 - 36,771 miles
Macan Brembo's Installed: May 28, 2023 - 36,821
Oryx White Golf R Mod List
Braking
Porsche Macan Brembo Calipers (95B-615-123-F, 95B-615-124-F)
PowerStop Z26-1001 (Macan Carbon Ceramic Front Brake Pads)
PowerStop Z26-1761 (Golf R Carbon Ceramic Rear Brake Pads)
Neuspeed Stainless Steel Front Brake Lines
Neuspeed Stainless Steel Rear Brake Lines
HAWK Talon Rotors 345mm (Front)
HAWK Talon Rotors 310mm (Rear)
MOTUL DOT5.1 Brake Fluid
Transmission
APR Shifter Cable Bracket
ShopDAP Holy Shift Kit
PowerFlex Dogbone Insert (80A)
Clutch Stop and Spring Removal
Engine
Integrated Engineering V2 Intake
Integrated Engineering V2 Carbon Lid
Racingline Coolant Re-route Hose
EQT Coil Ground Kit
APR Washer Reservoir
Racingline Turbo Inlet Pipe
Liqui Moly 5W-40 Oil
Remus Race Catback Exhaust System
COBB ABS Heat Shield
Racingline Billet Oil Dipstick
Racingline Billet Oil Filter Housing
ECS Tuning Carbon Fiber Battery Cover
ECS Tuning Carbon Fiber Fuse Box Cover
EQT Carbon Engine Cover
Suspension/Chassis
Alltrack Skid Plate Kit
SuperPro 24mm Rear Sway Bar
Moog Rear End Links
Racingline Carbon Fiber Chassis Brace
034 Rear Subframe Inserts
Racingline 80mm Stud Conversion
Unibrace UBQ
EMD Auto Flush Spacers (10mm Front/17.5mm Rear)
Software
Neuspeed Power Module
VCDS Hex-V2
Exterior
XPEL XR Black 20% Ceramic Tint
CJM Industries Rear Diffuser
BadgeSkins Vinyl Overlays
Genuine Euro Power Folding Mirrors
Genuine Euro MK7.5 Taillights
USP Motorsports Wiring Harness
Interior
Monster Mats
Rexing V1P Dual Channel Dash Cam (Hardwired)
BFI Leather Shift Boot (Silver Stitching)
BFI Perforated Leather Shift Knob (Black)
OEM Rear View Mirror with HomeLink
Uniden R7 Radar Detector (Hardwired)
Blendmount Uniden R7 Radar Detector Mount
Vagexpress Exhaust Switch
Carbon Steering Wheel
Genuine Euro Rear Headrests
Stocked Parts List
APR Charge Pipes
APR Intercooler Hoses
APR Intercooler
Integrated Engineering Downpipe
Vibrant Straight O2 Spacer
P3 Analog Boost Gauge
Audi RS3 Brake Ducts
Oettinger Spoiler
OEM Coil Packs
Racingline Turbo Muffler Delete
APR Turbo Outlet Hose
034 Lower Control Arms
APR Pendulum Mount
SuperPro 26mm Front Sway Bar
SuperPro Front End Links
TyrolSport Deadset Kit
BFI Stage 1 Engine Mount
BFI Stage 1 Transmission Mount
Audi RS3 Aluminum Subframe
APEX VS-5RS Wheels
PowerFlex Hybrid Subframe Bushing
Cobb Accessport V3
EQT Stage 2 Tune
KW V3 Coilovers
Vorshlag Camber Plates
034 Rear Trailing Arms
Dynamic Center Caps
_________________________________________
After having my daily driver 2007 Honda Odyssey for over 4 years, water intrusion started to get the best of her. The main fuse box started creating electrical gremlins and I decided to start searching for a new daily driver. I stumbled upon a stock black 2018 Golf R (DSG) with 113k miles. The body is a little rough with rock chips, but nothing a little touch-up couldn't solve.
Purchased: January 18, 2024- 113,223 miles
Deep Black Pearl Golf R Mod List
Braking
Zimmerman OE Rear Rotors
Transmission
Stock
Engine
K&N Drop-in Air Filter
SkunkWerks Coil Ground Kit
Euro Intake Manifold Cover
Suspension/Chassis
Exterior
Stock
Interior
Monster Mats
FITCAMX Dash Cam (Connected to Rear-View Mirror Harness)
MQB_7.5R
Ohio
September 3, 2022: 36,182 miles (WHITE)
After completing a 730-mile road trip home, I had to do an oil change.
I then installed:
APR Carbon Fiber Intake
APR Carbon Inlet Pipe
APR Coil Packs
Racingline Turbo Elbow
APR Solid Shifter Bracket
Shop DAP Holy Shift Kit
MQB_7.5R
Ohio
September 9, 2022: 36,315 miles (WHITE)
A little before and after the windows were tinted. Decided with 20% XPEL XR BLACK Ceramic Tint on the sides and back.
New Plate arrived for the car!
MQB_7.5R
Ohio
August 9, 2022: 36,405 miles (WHITE)
Installed:
BFI Leather Shift Knob
Alltrack Skid Plate
Moog Rear End Links
CJM Industries Rear Diffuser (Fin Style 4)
Badgeskins Vinyl Overlays
19birel
Pittsburgh
MK7.5 - MK4 - B8.5
Your MK6 was super clean! Great progress so far on the 7.5R, keep up the nice work!
Triple B
California
Golf 7 R
Clean GTI - what wheels did you have on that? Did you do all the shifter parts at the same time? Curious as to whether the metal bracket adds anything.
MQB_7.5R
Ohio
The wheels are OEM VW Rotary wheels. All the shifter stuff was installed at the same time. I had just a short throw on the GTI with the plastic cable bracket and I can tell the new one feels a lot more direct while shifting. I figured I might as well upgrade it while I had the shifter linkage removed.
MQB_7.5R
Ohio
Finally got around to hardwiring my Uniden R7 Radar Detector paired with a BlendMount mirror mount. I used a similar setup on my previous GTI and it was fantastic. Next up is to install a front and rear dash cam.
19birel
Pittsburgh
MK7.5 - MK4 - B8.5
Do you have a more zoomed out pic of how the R7 looks with the blend mount? I'm getting ready to mount my R3 and might go that route
MQB_7.5R
Ohio
Did you hardwire the uniden all the way to the fuse tap? Or did you use wiring behind the mirror?
I hardwired the Uniden all the way to the fuse tap since it was easier than taking the mirror apart. I swapped the original rear view mirror a month ago with one from a mk7.5 GTI so I could have the HomeLink (garage door) function.
MQB_7.5R
Ohio
November 16, 2022 - 36,532 miles (WHITE)
Hardwired Rexing V1P 4k Dual Channel Dash Cam.
