But your reasoning is not correct here at all (from a fluid dynamics perspective)
The bolded parts are just flat out wrong.
1. A bend in pipe is naturally very restrictive compared to straight piping, and for it to not be restrictive you would need to have a larger diameter in the bend compared to a straight pipe of a smaller diameter. Smoothness of the bend also greatly affects flow characteristics, much more than one might think actually.
2. The airflow coming into the turbo is being forced by the turbo, if it was natural unpressurized airflow then sure your point would be valid but it isn't. The thing we are concerned with here is pressure drop across the section.
3. You would see a
very significant difference doing dyno pulls with an "open turbo" (quotes because you need to make sure its getting fresh outside air)
4. Yeah, it is. That stock pipe is TINY because the plastic construction means really thick walls and a huge reduction in cross sectional area that is actually much smaller than the turbo inlet.
