I'm thinking about installing JB1. I thought this would be easy for me, but now I'm not so sure. I searched the threads and couldn't find much info on the installation. I saw a video, and it was done on a lift. Is this correct I need a lift, or ramps, because of accessibility issues?
If your hand is the size of a 10 year old’s, and your arm the length of Yao Ming’s, then you don’t need to put it on ramps.
Otherwise you need a T25 torx bit to remove the dust shield under the engine bay so you can access plug D once you’ve got it in the air.
It IS easy though. Just take your time with the clips, jimmy them as much as possible without using excessive brute force. The plastic is pretty brittle
