jay1337s
Slovenia
Golkf MK7
check the injector harness and/or ground wire ??
Those seem fine. At first there was just P1007 and after testing compression etc we replaced the injectors (all of them, not just one) and the filter..t he car was running smooth again and no codes. After driving 600km (in one day) it broke again on the same cylinder, giving the same P1007 plus P0087 low fuel pressure.
swcrow
7.5 GTI/'29 Ford
Neuspeed wheels......ball seat or conical bolts?
Edit....ball seat
Acadia18
sterkrazzy's exotic
Edit....ball seat
Benefit of Neuspeeds are they keep all the OEM spec. No adapters or different lugs needed.
You get the tracking # for the spare wheel yet?
manu97
Chicago
MK7 R
Any idea what could cause a soft clunk when moving from a stop some of the time?
Subframe maybe?
swcrow
7.5 GTI/'29 Ford
sure did.....that joker was shipped the same day and neuspeed called to confirm with me.....they definitely get an A+ for following up
Daily Driver
New York
2020 GTI SE
Random Bots have taken over the Posts! Now this will be on top again.
MonkeyMD
I spent 15 mins reporting threads this morning. Wasn't about to do it again
DSC808
HI State
2016 GTI SE MT
Can you use speed bleeders for the brakes? Most use Motive Power Bleeder to pressurize system to 30PSI to get past the ABS sensor then crack open.
I’ve seen videos on speed bleeders and you pump the brakes to pressurize the system and move fluid.
Would speed bleeders be pointless since the system is pressurized; once you crack open it’ll work like a regular bleed screw.
kyLman
Grand Rapids, Michigan
2015 Golf
Does anyone have suggestions to slow this down or perhaps how to DIY fix?
ChristopherNeil
San Diego
MK7 GTI
You may be able to do a patch reinforcement from the underside, but for the disassembly required to get to that point, I'd see if you could find a new cover altogether.
EDIT: What I found, assuming it's the driver's side. 5GM-881-405-AM-EVT
kyLman
2015 Golf
Great idea - i found the part number on VW's website (thanks to you sir), but I fail to understand if its the entire seat cushion bottom, or just replacement leather that I would have to wrap/install on the base?
wascally wabbitt
Southern Maine (aka Northern Mass)
2017 GTI S
I found these gouges behind the top window seal when I went to wash my car yesterday (photo shows the door propped open to reveal gouges). The gouges are down to the metal. What could've caused this? I hadn't opened that door since visiting a pal in Harrisburg, PA three weeks ago for a shooting range trip. I parked for two nights at his apartment complex where the average car was probably 15+ years old. Perhaps this was (un)neighborly funny business after someone saw several firearms going in and out of the car? Regardless, I'm not sure I'm comfortable fixing this myself, as each gouge is around an inch long.
Do guys think I should get USAA involved to fix it? My premium is only $250.
