So I installed my baun dp and midpipe this weekend and had a bit of a struggle lol. I have a 2018 gti and i purchased a used dp for a 2019 model which has a smaller outlet on the end of the midpipe to fit that year's stock muffler.
I had the end of my midpipe expanded but they didnt have a way to measure the size to get 2.5" exactly and it ended up being a little smaller than it should be.
As it is right now, the outlet of my midpipe is nested inside of my muffler and held with a clamp. I test drove it twice with that setup and both times the midpipe popped out of the muffler during acceleration. One was WOT and the other time was a mild acceleration. The midpipe was completely free and the muffler was hanging down with the clamp still attached to it.
I torqued the clamps down with a pneumatic impact so it was pretty tight.
Currently the assembly is held together with the same setup plus some heavy duty epoxy holding the clamp to the pipes. No epoxy inside of either pipe.
It's holding together and has for about 120 miles, but I believe I have an exhaust leak or some other problem. At low rpm everything feels and sounds great but around 3k and higher it rattles quite a bit and I dont think I'm holding boost pressure steadily. I never really monitored it before (I have a Cobb AP to monitor) but currently I'll have around 5-9 psi during acceleration even if I'm pushing it. It can get up to low 20's but it doesnt hold high psi for any significant length of time.
Could it just be that configuration of the midpipe to stock muffler causing the issues? I'm planning to work on it some more on my next day off work.
Probably going to cut the stock muffler back a little more so the pipes have more room to butt against each other rather than nesting inside. Might have to take it back to the shop that did the original expanding and try to get it right this time...
Any ideas?
Just an update to my situation for anyone interested.
I took it to the exhaust shop today after a week of dealing with a sinus infection that knocked me on my ass lol. They expanded the end of my midpipe a little more and welded it to my stock catback.
I also had an exhaust leak where the dp and turbo mate. My dp came with the ends of the exhaust hanger bracket nubs (not sure what they're called) removed so it fits a little strangely into the hanger bracket, which I think caused the seal to have a gap on the bottom end.
My roommate got under the car and rotated the dp while I checked the fitment of that seal and we got it mated nice and clamped back down properly.
Everything is working great now. Went on a short test drive and did a few pulls and it feels much better. Next step is to upgrade from the Cobb OTS stage 2 tune to something like EQT's tune.
Also didnt notice any drone on my test drive but it was fairly short and I wasnt doing much cruising lmao
