Long Term Spark Plug Thoughts
GoatAutomotive
Georgetown, TX
2017 VW GTI SE, DSG
tigeo
Almost definitely. The "RS7" plugs are also stock on the RS3, you don't hear about people blowing those up due to plug straps falling off.
Bro...0.02434566 repeating gap or you'll get knock....keep opening and regapping them bro (rips vape...adjusts flat-brimmed hat). Bro.
ZuMBLe
NY
Alltrack 6MT
I've noticed an increase in torque when using a 0.0243 gap vs .024 gap. That extra spacing allows for the optimal flame kernel for the dish size of our pistons. Turbo also runs cooler with 0.0243 gap, which lowers the charge air temp for denser cylinder fill. This is for pump gas btw. I use 0.0229 plug gap when I have E40 or above in the tank. Ethanol burns faster so less gap is needed to create the optimal flame kernel.
I'll bet there is 20 or 30 lb of torque to be gained when using the right plug gap.
tigeo
But let's get to the real shit here.....coil packs and grounding kit....which ones for 40 rolllllzzzzzz
ZuMBLe
NY
Alltrack 6MT
Both are important for 40 rolls.. But hub bearing clearance makes even more of a difference in that scenario. You want the least amount of friction as possible for roll racing. You'll get more power, with less boost when your hub bearings are properly gapped.
tigeo
So basically employ my winning Pinewood Derby technology here....graphite powder and optimal gap!
Salami
North Carolina
MK7.5R
So what is the proper hub bearing gap? Is it measured in car or bus lengths? Can it only be measured at Gaplbees?
ZuMBLe
NY
Alltrack 6MT
Talk to your tuner for the proper hub bearing gap for your car. It varies based on altitude and type of coolant you run. When your plugs and hub bearing are properly tune, you'll def be winning by bus lengths.
GolfRRRR1
Michigan
Herding the cats back into the subject, I run the Ruthenium NGK plugs on my Golf R EQT stage 2 and E30 tuned. Just pulled them again because of all the crazy spark plug talk, still look beautiful
GoatAutomotive
Georgetown, TX
2017 VW GTI SE, DSG
Thank you for that. They look quite healthy.
1) How many miles on them in this pic?
2) Do you remember the 4-digit NGK part number you bought?
3) And did these come pre-gapped in the .024” range?
(Asking for a friend) 😉
tigeo
Ruth's come stock 0.028 to 0.030 for the couple of sets I have had. I run them as they come.
GolfRRRR1
Michigan
1) How many miles on them in this pic? About 25,000 miles, 2.5 years ago, Golf R is my 2nd car.
2) Do you remember the 4-digit NGK part number you bought? LFER7BHX Stock # 95125
3) And did these come pre-gapped in the .024” range? I had to gap them myself, as others have said, they were pre-gapped @ .032
