Long Term Spark Plug Thoughts
PerceivedShift
$40 shipped isn't bad, no rush to get them so I ordered.
tigeo
I think mine were $36 delivered from Rock auto.
UA TDI
Central PA
MK7 GTI
How often are you guys changing your Ruths? I threw in a set probably 10,000 miles ago and they seem to be doing well. Sorry if I missed this earlier in the thread
I change them every 15,000 miles.
CaptainRatty
Winston-Salem, NC
MK7 GTI
Don't have FB. Are they blowing up because of the RS7 plugs or do they just happen to have them and they blew up their engine? How do we know it's the plugs?
Electrodes are breaking off and being sent through the motor, sometimes after the driver states they’ve only been in for 6-8k miles and then boom with no warning. I totally get how statistically it’s more likely to happen when you have a larger sample size and I’m not trying to be an alarmist, but I can’t recall seeing a single case of this issue with the Brisk or Beru RS7 plug in the last 6-8 months or so and I know those are popular options as well.
We also can’t be sure how many miles these plugs are being run for, how/if they are re-gapped, etc. It’s kind of a mess of anecdotal info; difficult to draw a solid conclusion from. And of course, I’m on my 4th set of NGK RS7 plugs with no issues.
aaronc7
Clovis, NM
yeah it's hard to say if they are failing because of shitty running / hard running conditions and they get broken off, or other way around. I've seen guys kill spark plugs/burn off the ground strap after a pull or two when running too lean.
Personally I've had good luck with RS7 and basically all I've ran since I had the car. I do worry about stock heat range plugs when you start running 200+ hp over stock etc. RS7 is my compromise for now. Safest bet would be the 2 steps colder plugs, but alas they are super expensive.
tigeo
There is just no way to know b/c the variables in these things aren't controlled at all. How are they gapping them (the obsession with gapping...it has to play in that some don't do it correctly)? What tunes are these happening with? How long are the plugs left in? Is it possible these are counterfeit? I've used the NGK "RS7" at their stock 0.026" gap in my IS38 Sportwagen beating the crap out of it for over a year with no drama, changed at 15K miles. Currently on Ruths...
Mr. Conundrum
North Carolina
2017 GTI Autobahn
Oof. That's very unlucky, for lack of a better word. Like you said, though, it's hard to say how accurately this represents things. It could also be a bad batch of plugs that were manufactured. In general, far more have had good success with the RS7 NGK plugs than have had problems.
I'm getting tuned next month and I'm trying to figure out which plugs to buy. I definitely can gap whatever I get to .024, though.
Escape Hatch
Mk7 GTI
I have a set of new RS7 plugs if anyone is looking to buy.
scrllock
MI
I'm sure there are thousands of people running them without problem, but a handful of people post about it here or on FB and that becomes gospel as a widespread issue. My guess is that people are compressing and pulling on the ground strap either with the wrong tools and/or taking so many tries to get it right that it's stressed the material at the bend. I'm sure there's a lot more people who've never gapped a plug running a stage 1 tune with NGKs than say a big turbo with 2-step colder brisks they're checking every oil change.
