Diggs24
- de plains! de plains!
- 2015 GTI
Fall is better boost weather anyways.
Try putting a loop in one of, or both, the sections of the feed line. Like the one from the sensor to the rail. That may bring it closer to the factory run. Or maybe routed more below the CC and back up to the rail.
You could add on of these and gain some length and also remove the potential bottle
Neck in the system were you are going from 1/2 down to the sensors size.
*also looks like that fitting where there is a green oring visible is using a female flair AN fitting on a none flair male end?
https://www.motionraceworks.com/pro...or-return-6an-8an-10an?variant=34295437688972
