Sorry for the question, but how do you know I'm riding the E30?? Did you see it in the logs?
Isn't all fuel in Brazil E30? I thought that was the case.
Oh yes!!! In Brazil there is 27% Ethanol in gasoline!! But I actually run a little more ethanol in the E50!!Isn't all fuel in Brazil E30? I thought that was the case.
Did you mean there is no delay in IGN_2, 3, 4 and 5?No wonder you're able to pull off the timing numbers you are.
Follow the logs with Fuel Bias 50 between 5000 to 7000rpm!!
It seems that the AFR has improved, but the turbo result was not satisfactory!!
I would like to understand why when I log on map 0 the pressure of the ECU_PSI for example at 4040rpm ECU_PSI = 23PSI, and when it is on the map6 in the same rotation range ECU_PSI= 20psi.
I think I have turbo efficiency problems.
https://datazap.me/u/djdouglaslopes/log-1643480327?log=0&data=1-2-3-4-11-18
https://datazap.me/u/djdouglaslopes/log-1643480835?log=0&data=1-2-3-4-18
Come on, so I should lower the FUEL BIAS to 50 at all revs, correct?You should lower the fuel bias in the lower RPMs also. Looks a bit better from 5000-7000 though. Keep it there.
You shouldn't be looking at ECU_PSI. Not sure why people do that. That value is the number the JB4 is telling the car the boost is to raise the boost. What you should be looking at is DME_BT which is the boost value the car wants to run.
My turbo is a hybrid IS20, similar to an IS38 but with the IS20 housing, understand?? Here it is called IS28.....hehehehehYou'd be very safe if you just got the AFRs to be around 12.2-12.0 through the whole pull. There is really no reason for you to be as rich as you are at your your boost levels and with so much ethanol in your gas.
The JB4 doesn't log enough parameters to really trouble shoot if it's a hardware or software issue. Is this an IS20? If yes, 20 PSI at 6000 RPM is really not bad at all.
But even so, I will lower the FUEL BIAS to 50 in all ranges and test it!!
Is your car stacked too?
Nice....When you stacked the JB4 with APR, did you use OEM turbo (IS20)??I don't use my JB4 anymore (still connected but Map 0) but always had it stacked on a APR tune when I was using it.
Don't bother viewing the ECU PSI anymore, the DME_BT is the boost your flash want to run. The ECU PSI is pretty meaningless.
Your running a different turbo than OEM, and also running a flash creates a lot of variables which is going to be very hard to troubleshoot with the JB4. You should start by making sure your wastegate is properly calibrated I guess. It's very possible the base flash just doesn't have enough wastegate up there to create more then 20 psi. The JB4 can't control the wastegate on the VW/Audi platform so you're kind of stuck there.
So, as I said, the flash that is in the car's ECU, for sure, has the wastage setpoint modified, so it can't pour more than 20psi!!
But what worries me are the results of the AFR...let me see if I'm right
AFR RICH (11, 10...)= NOT TOO MUCH RISK OF EXPLOSION
AFR LEAN (14....15....) = HIGH RISK OF EXPLOSION
Would that be more or less?
Really here in Brazil the AUDI 1.8 8V comes with a 1.8 engine and IS12 turbine.....usually many people upgrade to IS20, but the gearbox that comes with these models gives a lot of problems (S-TRONIC 7 CLUTCH DRY), and don't exist here with manual gearbox!!!I have an Alltrack so I had APR Stack on a IS12, and APR Stack on IS20.
Yeah it's very possible you won't be able to make more than 20 psi., (check with George maybe) but that's plenty of cylinder pressure if you're running 11 degrees of advance on a 2.0!
You're just wasting a lot more fuel than you need to. You're making the fuel pumps work more than they need to. When you're overly rich, the engine just doesn't seem to have the same pep either. You should be very safe at AFR 12.0.
In this photo, it is the value only stg2 E50 with IS20!!! Came a very good power!!I have an Alltrack so I had APR Stack on a IS12, and APR Stack on IS20.
I didn't have the opportunity to run the car through the dynamometer with the current configuration (STACKED JB4), but I think it should come to about 320hp. what do you think?
I understood!! Must be giving a gain of more or less 50cv peak!!The "general" rule is usually each PSI you run over base is about +10 HP if you're within efficiency of the turbo. So take your BOOST value and subtract DME_BT and then multiply that number by 10 and you will get a ballpark of how much power over your base tune at that RPM.
You probably won't understand this phrase, but it's "bro math". Just consider it a very general rule.
