Mrpie187
- Long beach
- 15'GTI 6spd
@ChrisMk77 @Diggs24 can u guys do a map 6 tune for me i don't mind paying for it
Would you be willing to do one for me too based on my previously posted map 3? I know it was recommended to taper down .5 psi after 5k rpm but I don’t have a good map 6 set up. My car is just a DSG with a drop in intake, snow guard removal and RS7 plugs. I plan on using map 6 as my blend tune with attempting to get as close to E30 as possible.yes. no payment. you can donate to charity instead. ill build one tonight. full mod list please and gas you plan to run.
You need an intercooler first. The shortyb settings above should work for an eblend tune. Set FOL to 60.Would you be willing to do one for me too based on my previously posted map 3? I know it was recommended to taper down .5 psi after 5k rpm but I don’t have a good map 6 set up. My car is just a DSG with a drop in intake, snow guard removal and RS7 plugs. I plan on using map 6 as my blend tune with attempting to get as close to E30 as possible.
Nice, might try thisFound it.
"I have drop in k&n drop in filter gfb diverter valve catless dp intercooler intake tube turbo muff delete turbo inlet pipe
and a sachs stage 2."
Try this:
1500-18
2000-19
2500-20
3000-21
3500-23
4000-26
4500-25
5000-23
5500-22
6000-20
6500-19
7000-18
Just make sure you have good fuel, that was an issue before for you IIRC.Nice, might try this
And someone with FBO running E30 could try logging map 5 to see if its good on the newest revision (25psi tapering to 20)
stock
so that accordion isnt restrictive? I thought it was proven by that one guy who does those flow tests and all sorts of awesome tests.
