MauricioGTI
- Brazil
Well, it's still having a hard time hitting your boost request (pink line). Your actual boost values (dark blue line) are also jumping around in the 3k-4k range. Your timing (IGN1) never gets above ~7 at any point. I have to think the high heat is to blame. The car may actually be faster if you turned it down about 2psi across the board.
Yes, my car can not track the target in any way on the absolute map. The advance was 8 degrees.
