gboticus
- Vancouver, BC
- 2019 R DSG
DS1.11 are definitely a step up but to add to @DerHase 's comment, I think 3.12 are really the right choice when you start to get good at tracking Unless you have a massive BBK and 18mm+ thick pads the extra friction and heat capacity of the 3.12 will be the right choice longterm.At the shop for the monthly visit. Driver-side output shaft seal is leaking. I'll be real annoyed if the gearbox has to come out again given that was supposed to be replaced when they did the diff. Dunno what's up with the turbo yet.
In the meantime, shopping for brake pads. DS2500 definitely aren't cutting it anymore. Comparing some options, DS1.11 is pricey but I can keep the 2500s for street use, and I know I like those quite a bit. I'd prefer to have a set of compatible street/autox pads to keep the girodiscs going longer, so that's a price consideration as well.
DS1.11 F/R: $583 (with GBP exchange rates anyway)
Endless ME20 F/R: $705 (+$675 for MX72 F/R)
Gloc R12 + R10: $478 (+$414 for R6 F/R)
iSweep IS3500: $515 (+$425 for is2500 f/r)
Porterfield R4: $510 (+$320 for R4-S)
Endless just isn't economical and there's limited info on the higher-end isweep pads. The cookie cutter R12/R10 combo makes a lot of sense given the long-term costs of replacing the fronts, especially with domestic vendors. Ferodo is stocked stateside but for much higher prices (almost $700 for FRP3067W).
EDIT: After looking at the track pad thread in the other forum holy cow, glad I didn't do 3.12F/2500R.
