Autobahn
- Huntington Beach, CA
- '18 Golf R
Good progress, the build is shaping up to be a good, reliable one you can push on with little worry at the track ?
I only ever bought one thing from PDC: a steering wheel with a red centering stripe. When I received it, the stripe was an inch off center and when I demanded a refund I was told that "it wasn't functional" and that "I was measuring the center of the wheel wrong". Absolutely infuriating dealing with the owner and baffling that they would claim that it's ok for a centering line to be so obviously off center. I eventually had to ship it back to Malaysia for them to send me a new one.PDC "vented" hood finally arrived.
Ok, so there's a grille in the middle vent, cool.
And the side vents are totally blocked off. Uhh, what?
Flip it over and there are zero actual vents. Wtf?
Sent them an email but I'm not sure what the point of this is.
Product says: "Vented top mid and side fins with heat dissipation design" but I'm not sure what's supposed to dissipate heat?
Waiting on them to respond but a 9 month wait for this crap has me looking at filing a charge back. Not sure if Amex will help given it's _way_ out of the normal refund period.
For sure, I've never done body work but I assume anything involving fiberglass requires PPE.Huh, I was looking into order this same hood as well (but the level 2). Disappointing that the vents aren't actually functional.
If you are going to Dremel it make sure you're wearing a respirator and not just a mask covering as well as proper gloves and a long sleeve. Carbon fibers are worse than fiberglass but the real danger is the epoxy, which is highly toxic.
Maybe you can modify the hood to resemble this, feel like this design would cause air to be sucked through the opening.For sure, I've never done body work but I assume anything involving fiberglass requires PPE.
The level 2 comes with the vents open, but the main path for air out of the bay is through that small piece at the back which leads to the chamber that's open to the small side vents and the main vent over the heat exchanger stack. I would expect much better results from a vent that allows for heat to exit directly above or behind the radiator/intercooler.
If it can be made to fit with a stock radiator, this would definitely be the best solution (though you have to go through a race team):
i think the air being pushed through the grill would be stronger than the slipstream sucking back over the topMaybe you can modify the hood to resemble this, feel like this design would cause air to be sucked through the opening.
Compound effect?i think the air being pushed through the grill would be stronger than the slipstream sucking back over the top
so you don't have any openings on the bottom of your hood besides the rear center opening?That is interesting. I have a level 2 hood and the owner at PDC said that it does remove heat from engine bay and has the same underside as that photo of the level 1 you posted. I even tested it using a leaf blower in the front while holding my hand over the vents and I did feel hot air being blown out from the vents on the top of the hood as the air passed through the grill
