Tyler@IE
- Salt Lake City, Utah
2015-2018 GTI is now fully supported on all stages (Stage 1, Stage 2, & IS38)!
Unlock the flexibility to run 91/93 octane all the way up to full E85 or anything in-between all from one tune. These performance-based flex-fuel tunes maximize and adjust power and torque instantly. Say hello to the easiest, fastest, and safest way to run ethanol for your
MQB 2.0T engine now: https://performancebyie.com/products/ie-ecu-tune-vw-audi-20t-tsi-gen3-is20
What is TrueFlex?
IE's software engineers and calibrators have developed our own advanced TrueFlex calibration, allowing the ECU to safely adjust for ethanol content down to the exact percentage in real-time. This powerful programming brings the ease and confidence to fill up at the pump and make the most power available from your fuel choice without having to drain, verify blends, or reflash the ECU. Simply fill up any mix of ethanol and pump gas (91/93 up to full E85) and go!
Is this flex-fuel?
Factory-equipped flex-fuel calibrations are designed to adjust for the cleanest emissions for different ethanol blends to get the highest MPG. This typically results in maximum timing for the lowest octane (91) across the entire range up to E85, leaving loads of untapped power on the table. IE TrueFlex is a complete performance adaptation that makes instant and continuous adjustments to performance maps such as boost and timing and releases the most available power for the fuel mix as it enters the cylinder.
What is required?
-TrueFlex Sensor Harness Kit: The EA888 Gen 3 2.0T engine is not equipped with any type of Flex Fuel system from the factory and lacks the ability to sense fuel content. In order for IE's TrueFlex ECU tune to work, an IE TrueFlex Sensor Harness Kit is required. This easy to install harness kit installs a sensor capable of delivering instant fuel content data to the IE ECU calibration. https://performancebyie.com/products/ie-trueflex-sensor-harness-for-mqb-engines
-DSG Tune: Due to the high-power output of IE TrueFlex ethanol tunes, the IE DSG TCU calibration is required to prevent the factory clutches from slipping under load. Additionally, the DSG calibration will deliver a higher RPM limit, faster shifts, optimized shift points, adjustable launch control, and a true performance-tuned transmission. Acceleration times will greatly improve giving you the most performance from your TrueFlex ethanol tune. Manual transmission vehicles require a clutch upgrade. https://performancebyie.com/products/ie-dsg-tune-vw-audi-mk7-8v-dq250
-HPFP Upgrade: Ethanol offers higher power output but also requires more fuel delivery than regular pump gas. The stock High-Pressure Fuel Pump (HPFP) can not deliver enough fuel to support ethanol and must be upgraded. Upgrading the HPFP ensures there will be enough fuel supply for ethanol content to run reliably at all elevations and climate conditions safely. IE HPFP Coming Soon!
What is TrueFlex?
Is this flex-fuel?
What is required?
