hissing, high-pitched noise
Gomze
France Marseille
Golf 7 gti performan
Hello friends
I have a noise when the turbo is charging hard between 3000/4500 rpm for 1/2 seconds. "the noise looks like a beep"
at 5000/6500 trs the car no longer makes the noise
I thought about a wastergate problem
ideas ? pcv? wastergate?
the car drives very well and without cell
have a good day
launchd
New York
2023 M3LR, 2021 A7
What model year is your GTI?
Ok diggs, thanks you
my wastergate can not be the cause of the noise and the fault? how to control it?
He is saying if you have a boost leak the wastegate will close more. Not that the wastegate is the problem.
Go to a shop and have them ride in the car with you to hear it.
NBMK7GTI
thank you
I actually replaced the intercooler with a forge 5000km ago
is your leak on the hot or cold side boost circuit?
All I did was tighten my intake clamps, so that’d be the cold side. It’s an air induction noise so most likely nothing to do with the hot side. There’s about a post a month like this on the various facebook groups.
MSH
Denver
'20 M2 Competition
Similar sound on mine that is annoying as f but I've learned to live with it. I posted the below back in Sept. Still have noise. The car in that Youtube clip is not my car but noise is very similar.
After this post below I took it to my shop here in Denver that ran pressure + smoke tests...nothing. Their log w/ VCDS - https://datazap.me/u/quattrowerksatt1/log-1601566199?log=0&data=0-4-5
Car runs perfect(other than damn noise), all subsequent logs look great (confirmed by Nick @ EQT), dyno #"s were solid after all my Vortex tunes were done.
I have found other youtube vids etc that indicated a simple intake change solved the issue. Something about maybe some weird harmonics come into play depending on your set up (mine...R600 (cotton filter but did it w foam 2)to MST TIP to Vortex std) Havent bothered to swap back on stock airbox to see if it goes away.
https://www.golfmk7.com/forums/index.php?threads/eqt-e-tuning-q-a.361928/page-99#post-7506668
branman1
DE
2019 GTI 2021 GLI
Not sure if this will help. I had this same noise when I went is38. I am running an IE v2 intake and IE turbo inlet pipe which I had before going is38. So far I tracked it to the turbo inlet pipe. If I put the stock one back on the noise goes away completely. I put the IE inlet pipe back on and the noise comes right back. I even bought a 034 turbo inlet pipe to try and it makes the same noise. I think you are onto something with the harmonics.
  • Like
Reactions: MSH
