Diggs24
- de plains! de plains!
- 2015 GTI
Gotta get in my dad jokes when I can.
We got some things in the works.
I think the controller is bullshit and we are going to try to bypass altogether. For now its pegged at 83/84% max but still don't know why it tripped a fuse .
It did sit and idled at first for like 20-25 minutes and apparently you're not supposed to do that with the 525s? Idk about that but why it blew at first is the real question.
Don't need one for the Tomioka, or are you upgrading?I too don't want to spend the money on PM4 so my tuner was thinking of doing a hardwire mod on a Hobbs switch that only works above 15 psi. I'm too chicken to try it though.
yes. added mpi last weekend.
What is the fuel pump speed “common error” that was mentioned in this thread? Sometimes I get a “fuel pump engine speed too low error”. Is this what was referred to? Can anyone here shed light on what this error means?
These channels are not accessible through maestro. The PW from ecu to controller is not matching up to the drive speed of the pump (duh cause you just made it 20-30% bigger) so it trips a CEL.What is the fuel pump speed “common error” that was mentioned in this thread? Sometimes I get a “fuel pump engine speed too low error”. Is this what was referred to? Can anyone here shed light on what this error means?
It just needs to be coded out once car is 100% running perfectly but isnt something to super worry about.
However my issue is quite alarming as the car itself wont drive if it keeps doing this and could possibly start hurting hardware. Its basically running around with fuel rail pressures that are max WOT at idle and light load. So imagine its like doing a wot pull for 20 minutes straight. Lot of load on electrical and other components.
It sounds like you may need a FPR in line before the rail like PR sells with the Stg3+ kit? Or, echo- PM4Has anyone ever had this issue when installing 525? My rail pressure just keeps creeping up and up and up at idle and light load until finally thwyre literally at max regulated pressure 7200+ . They just slowly keep going up for no reason.
We're pretty sure this is what tripped fuse the first time. If I let it idle for more than a few minutes it just won't stop building insane amounts of pressure
