Fitting the GTI LED tail lights on Highline - retrofit.
comingabriel
Southeast
Also, when the car is off, HL switch on or off, no brake or any lights will work.
Ideas?
Edit: locking unlocking car the ambers work.
capitan828
los angeles
You made a mistake on the coding for the running lights
As far as brake lights when the car is off, mine doesn't do it either. I don't think they turned on even before I did this mod.
They should when you think about it for safety reasons
comingabriel
Southeast
What do you think about this?
sigi_dr
belgium
Gabriel,
The coding you posted is NOT for LED tails, those are for halogen!
for full brake lights on LED's you need to use 27NSL !
i'll explain:
on halogen tails, 23SL and 24SL are the inner brake lights, that's why they tell you to set function C to brake light
BUT on LED's, 23SL and 24SL are the bicolor leds that run through the blinker, and as you can see in the second pic you posted, function A already defines them as brake light..
so on LED's, both inner lights are controlled by 27NSL
Grtz
comingabriel
Southeast
Gabriel,
i'll explain:
Grtz
HIIIII :)
I did! Still bright inners when switch is on, but work fine when switch is off.
(8)-Leuchte27NSL RC6-Lichtfunktion C 27 - set value to Brake light (default: Not Active)
(10)-Leuchte27NSL RC6-Dimmwert CD 27 - set value to 100 - (default: 0)
I have both my old and new maps side by side, with all the adjustments (highlighted), and with the 2 above, all correct. Going to email to you, so you can see I am not crazy. This is odd.
sigi_dr
belgium
HIIIII :)
ok, i'll take a look!
so if i understand correctly: when your lights are on, you only have 3 brakelights, when lights are off, you have 5 ?
Grtz
comingabriel
Southeast
Out buying a repair/resell car, will make a video when I get back.
Did not send file, on laptop, will email that as well.
Noticed 2193 (new count, minus 7) coming from 2196 (old count, minus 7) btw.
Highlighted each (3) old lines in blue, that were from the old map, and not on the new map.
sigi_dr
belgium
you mean the amount of lines in the admap?
i noticed the same things, i guess they are read errors..
don't think you should worry about it
comingabriel
Southeast
Here is the part number 000 979 009
Two different types of crimps on BCM.
The above PN (add E or EA to the end now) connect on the insides of A/B/C BCM blocks, while 000-979-025-E connect on the outsides of the blocks and everywhere else relating to the tail lights.
The pic below shows the two types of crimps on the bcm.
The left go on the inner rows, the one on the right on the outer rows and to the tail light male plugs (that plugs to the lights).
Again:
The right row (outer) of wires are 025-E crimps.
The left row (inner) of wires are 009-E crimps.
As cap already mentioned/posted, where you can buy the crimps (Deytrade) and tool in a former post (pic below of what it looks like and runs like $14).
Can also find them both on ebay.
My Golf R only needed 2 x 009-E crimps
(for A60 and C31, if you dont want to cut and re-use the ones mentioned in the instructions)
About 7 x 025-E's (for X wire (2), Y wire (2) and grey wire (2) and 1 x for A65 to C3 extension).
FrancescoA85
Milan
EU GTIMK7 LED Tail lights installation
Hey guys :),
I need your help; I have EU GTIMK7 2015 with standard tail light, and I have purchased EU Golf R LED tail lights, but I'm ultra-confused about how to install them correctly:confused::confused:
I would like to:
1) Avoid to cut the original wires
2) Avoid to code but whitout having a board computer error
3) Obtain all the correct function of arrow light and rear fog light
I read all the thread but i'm really confused.
maybe possible to have a good DIY guide to this job correctly; I would like to do today or tomorrow.
Many thanks :):):):)
sigi_dr
belgium
If you have an european GTI, you should have GTI LED tail lights?
I checked the website of VW Italy, GTI models already have LED's so why spend a lot of money to replace them?
Replacing GTI LED lights with R LED lights is done in 15 minutes, just change the light blocks and your done..
Grtz
FrancescoA85
Milan
Hi sigi-dr,
I can assure you that EU GTI for Italian market have not LED tail lights (also on car configurator VW Italy you can see this)
So I have syandard tail lights.....and the LED version in the box...
Please help me.
Thanks
