Sorry, yep Golf R with 93/e30 fueling. 96/28psi settings
Sent from my SM-G973U using Tapatalk
Doesn't look like you have a full Maestro map. Boost is limited to 25psi if you don't have the full Maestro suite. Also interesting that timing looks to be tapered in below boost onset and then ramped back up again.
Both logs look to be pretty equal on timing up to 6k RPM. The log with corrections doesn't look great up top. Nothing looks out of place in the log that would have effected the timing that negatively. Could have been a bump or something else. Others will hopefully chime in if they see something.
Hit the TQ limit
Or are you talking the tq limit of the file? Thinking back to the run with corrections it's definitely possible I hit a bump. I know the clean one was a smooth road for sure.
But if I'm hitting the tq limit of the file then it doesn't really matter what changes I make anyway...
No offense taken at all. Thank you for the help! Yes it is the standard stage 1.5 adjustable file. That is all that is done to the car. Is it just that a car without a downpipe can't hit 25psi+? Or is it just since I'm hitting the tq limit and that's the file's way of adjusting? I just reflashed the file and took it down to 24psi from 28. Set octane to 93. Will relog and see if the behavior changes.
The limits are ultimately defined in the file, not by the sliders. The sliders allow you to adjust up to the limit.
Your boost limit in those logs was 25.6psi, if you had the sliders at 28, than 25.6 is the limit for that file.
This seems sensible to me, you still have a stock cat which doesn't flow very well, and you're putting a lot more heat into it than was intended.
The boost target was reduced at the point of the TQ limit, but raised back to 25.6 after the calculated TQ moved away from the limit.
So it sounds like the torque limit of the file is causing the wastegate problem as well as the boost target vs. actual difference? Is that right? I'm unsure of what to do from here. Is this just par for the course on the standard adjustable file? Or do I need to talk to Chris? Should I flash back to stock and log to ensure there are no hardware problems? Sorry for all the questions.
You need Maestro
