razorlab
- North Jersey
- 15' GTI, 18" AT
Perfect. I was most interested in the trim effect. I have set the parameters to active (1). I used the factory 85% value, but will test my local ethanol to check content just to be more precise.
I imagine that based off of your description, that these settings help adjust the fueling to accommodate for the additional ethanol, and the slider settings can then be adjusted after to test/optimize timing advance/knock values.
FYI, tested this yesterday, it indeed works as I described. However I don't have active/inactive settings with my 1.8T ROM. It just works when you put a % in the table and it is global.
