Hi folks, I’ve been reading up on here and I’ve been getting the itch to retrofit my NA 2015 GTI DSG SE with MIB1. (Backup cam, Fender, no nav; lighting package; ) I have an OBDeleven. The primary goal is to get CarPlay & make sure all standard VW options screens are accessible. I've been spending ~3hrs/day in my car over the past year and am hoping to improve my quality of life in the vehicle.
I'm trying weigh the cost vs effort with the DIY vs Kit route.
- DIY route. Buy my own parts (presumably used MIB2/6.5" or 8" display from parted out vehicles). Install. Find a VDS cable/rental provider ; Reach out one of the recommended coders. I've included my cost breakdown below.
- Pros: Most cost effective option - can easily save $1000-$1300 vs a kit depending on your price shopping skills.
- Cons: a fair amount of leg work and planning is needed to get all parts and tools, then coordination with service providers. Some level of risk, as there likely limited or no warranty support on parts.
- EuroZoneTuning Kit - VW MK7 Discover Pro MIB1/MIB2 to Discover Pro Retrofit Kit- includes 8" standard display + radio removal tools. $1800+. 2015 MIB1 owners must buy the $140 Carplay/USB connector (the OEM usb/aux retrofit for the MDI connector or possible USB port if you were fortunate to have one). TInstall. Activate a few things using my OBDeleven.
- Pros: Gets you everything all at once from 1 vendor. No additional coordination OEM warranty appears to apply on parts - 6+ months depending on the part. Official support from EZT.
- Cons: ~$1000+ in additional cost vs DIY approach.
One possible additional fee is whether you hire a car stereo installer to avoid the personal cuts/nicks/frustration of routing wires in tight places. Just as reference, BestBuy charges $100 to install a touchscreen display model - so figure somewhere in the neighborhood of $75-150 would probably be a good ball park if you also need the USB module installed with an indy.
Here's what I currently have on my budget list for the DIY approach in the US (as of June 2022). The information in this thread spans several years, so please correct me if any of my estimates are grossly off:
- $150 mib2 brain (local) - 3Q0035844B - options from 2018 Golf, 2018 Golf-GTI, others from Tiguan, Atlas, Jetta, Jetta GLI.
- $150 6.5” display (local) - 5G6035868 - options from 2018-2019 Golf GTI, others pulled from Tiguan or Atlas
OR There are also lots of 8" displays - 5G6919605C available for ~$200 used on eBay; even brand new never used units for ~$400.
- $50 bezel to fit 6.5” or 8" display (possible local or AliExpress) - (not sure if bezel is needed if I opt for 6.5")
- $70 usb/aux retrofit (AliExpress)
- $30 - rental of VAS 5054 cable & radio removal tools for remote coding (assuming the folks that used to post here and VWVortex are available)
So estimate $400-500 range for all the parts. (I figure good bargain hunter could save perhaps a few hundred on parts vs my estimates)
I haven't seen coding fees posted here, out of respect for the folks providing this service - but from what I gather most of the folks charge based on a general rate + the cost to get specific licenses activated. Or not. It's not entirely clear to me if the existing licenses that apply to your VIN are applied transferred to the replacement units, or if the coder also needs to purchase new licenses then apply them.
I'm going to assume costs of $300-500 USD for coding, with ~30-60 min to complete all activities.
So I'd expect to spend in the $700-1000 range USD on the DIY Upgrade. Is my math consistent with other folks' experiences?
A few additional questions on the DIY approach:
- For parts, is there any advantage if the MIB2 and display come from the same model/specs (in my case a GTI) vs another model? Does it matter whether the units are made for US vs other markets?
- Do both the MIB2 and the display each have separate CPs?
- Are there any US/North America-based coders that can do the work in person - or is this such a niche skill/access service that this is the only way?
- What help (if any) can we get from VW dealer service shops? Could someone potentially buy a brand new MIB2 or Display from VW and they'll cover some or all of the coding? (or is this sort of retrofit work outside of their authorized work?)
