Quebster
- Dallas, Tx
Hi all,
Does anyone know if the amount of wobble I see in the pulley is normal? This will pretty much give me the answer to my issue. If it's normal, then clearly the crank hole in the lower cover got messed up somehow.
Vid 1, with belt:
https://youtu.be/74I8da-z7I8?t=39
Vid 2, no belt, leak fixed:
https://youtu.be/t5XMdWeJxBI?t=29
Vid 3, OEM pulley on, slo-mo.. best vid:
https://www.youtube.com/watch?v=pi18tshx8XA
Issue:
So I got my head put back on recently by myself, did all the timing myself and all that stuff, a huge first for me. Started the engine the other day, everything seems pretty great... except a noise from the pulley.
It seems that the pulley is hitting/rubbing the lower cover as best as I can tell. I'm trying to understand why. I see two possibilities:
1: Timing cover crank hole was damaged and maybe bent when I tried to pull the old seal out (unsuccessfully), or when the little shop close by pressed the new one in (I noted lots of clamp cosmetic damage around the hole).
2: I somehow got the 3-stage sprocket that sits between the pulley and the crank a little off somehow, even though it should be very difficult to do so thanks to the way it fits onto the crank.
You can also see where I believe the pulley is getting rubbed here:
Anyone have any thoughts?
Vid 1, with belt:
Issue:
