So rather than continue to highjack the other thread I thought it seemed more appropriate to post separately.
Background: just installed Redshift Standard Comp coil overs with 8k front and 10k rear. I also installed a super pro front sway bar along with new bushings. The coil overs came with new adjustable endlinks.
I made sure to adjust the endlinks while the car was on the ground. Best I can tell the middle adjust had some play in between too long or too short so I locked them in that spot.
The ride is… unexpected.
I’m getting a crashing, thumping noise over the smallest of road imperfections. Both videos are with the dampers on hard. The noise is SIGNIFICANTLY worse on or anywhere towards soft. It’s as if I hit a giant pothole with the factory suspension doing 80.
Is this normal? -it can’t be right? It seems extreme. I expected the ride to be more harsh but not like this.
What is happening?
https://youtube.com/shorts/3JGj9XAU624?feature=share
https://youtube.com/shorts/zuAQmIc9zjs?feature=share
Edit: in the video it very much sounds like a rattle. It is not. It is a hard thump
What is happening?
