Strange Mud
- Small Town CT
- Assorted
I wasn't thinking of trying it, but I would run same G as what's there. It would be solinoid so 10/12?
Very nice write up! Amazing!
I've been trying to source all the materials, and I find it hard to get the springs and solenoid.
For some reason the websites linked do not work, and I cannot find the parts online on any other website.
Any tips here? Anything I can get from Amazon or maybe from another website?
thanks, i got it working though. i've also found that the strength of the magnetss matter also. i was using rare-earth ones and they are really not needed. the field strength becomes too much and in-retracted position did not allow signal to de-activate..lets hope all this work helps save the thrust-bearings for a longgg-time..thanks again for pioneering this.
The Testco-Inc links work just fine.
https://www.testco-inc.com/ledex-solenoids/153914-001
https://www.testco-inc.com/ledex-solenoids/195207-225
The mobile version for me is missing the "buy now" part of the interface. You have to click "full site" at the bottom (or use a computer) to see it. I dunno if that's what he meant.
Can you show us what magnet you did use? It's hard to imagine a non neodymium magnet small and strong enough to work.
You punched a small hole in the rubber stopper for pushing the the rod end in a bit (with glue)?I assembled everything but have yet to get a good solution for adhering the magnet to the solenoid shaft. The small plastic plug / stopper I'd found that fit a magnet perfectly didn't take to the epoxy, same with the rod itself.
Once I've got that part figured out it should be easy peasy.
Wish I had a picture handy, but yep, rod into the stopper behind the magnet.You punched a small hole in the rubber stopper for pushing the the rod end in a bit (with glue)?
I used 2 part epoxy and it's been good.Wish I had a picture handy, but yep, rod into the stopper behind the magnet.
I need to try another adhesive that won't mind actually bonding to the shaft and rubber (looking at you JB weld...)
