Clutchless ignition update: solved (maybe)
Golf7RR
NE
On page 5 you said you updated your shapeways link with the new file.
Searching thread for shapeways and tinkercad, I cannot find it.
Any chance you have either link in your browser history. And could spare the time to re-share.
I think this is what shapeways sent me back when they fixed it. change filename extension to fixed.stl and check it out yourself with shapeways. but should be good.
  • fixed.zip
Ridebjj
lasVegas
This looks right when I import it, thanks. I'm going to update post #1 to include it and probably also a more concise list of everything used.
joedubs
For the record.
Mine works ALMOST every single time.
If the car sits for an extended period, I do just have to press the back of the piston to "release" it. After that it works flawlessly for days until it sits again.
I didn't use non metallic screws to mount it (I tapped the bracket and used some bolts that I had laying around), and my piston might be retracting a tad bit further than it "should" based on the way I epoxied the magnets to the end. Either way though, it's a small price to pay.
Ridebjj
lasVegas
For the record.
try getting in there with a very fine paintbrush with some grease on the end. Push the plunger out and then give it a thin coat of the grease, with a little extra dab at the very end by the magnet. Should prevent sticking.
Also, post #1 updated with new mount links and other parts.
S1ack
NC
Mk7 R
Looks good. Many thanks.
Edit: I ordered 2. Will experiment with tapping the holes. I figure I will bork that once.
My rib cage is already hurting thinking about the install.
joedubs
Tapping if worked fine for me. It was just somewhat brittle so it took a LOT to get it started and I'm sure it would strip relatively easily. Fortunately it doesn't require a lot of torque (and I could always switch to using nuts on the back of it did)
Ridebjj
lasVegas
I do think you could get away with a print in plastic or something that could be done with a better than average consumer level printer.
I did steel just in case my measurements were off and it needed bending / modifying to make it work. Steel was cheap enough but it was a 3 week turnaround. Turned out, I got it right on the first try.
If you have quick access to a decent printer it's worth a try, I think.
Ridebjj
lasVegas
Ridebjj
lasVegas
For the record.
You did the thing with the marker cap? Also, did you fab your own mount? I thought someone was trying that.
Also, pics! Do eeet.
Golf7RR
NE
First post updated with new link.
Also, my final set up used 2 of the 6mm. It worked better one way of the two possible polarity orientations. I'm not sure I remember which.
I had the end piece pop-off, and i put everything back together and now can't rid of the "operated" first clutch message. But it does go away when i insert a screwdriver in the space between magnet that is retracted and the sensor. in essence it is either collapsing or diverting the magnetic field i think. very weird. 2nd message works fine during retracted phase and extended phase..will work on it more tomorrow, but was fine for a long while (month or so i forgot)..
