Here's a possibly important bit of info I completely forgot about until I was down there cleaning in that area.
There's another direction of movement of the rig which can change how well it works or not.
If, after mounting it all up, you're having trouble with one of the sensors not activating/deactivating, try very gently pulling the solenoid unit towards you, such that it's very slightly pointing the extended magnets more towards the firewall.
If that does the trick, you can put a small spacer object between the solenoid body and the foam on the firewall behind it.
Mine has a little rolled up bit of duct tape stuck in that space to hold it in that position.
I can't believe I forgot this.
