hey guys, i have been checking my jb4 logs and noticed my IATs are climbing quickly but doesnt go below 40-45c as it used to, been running aftermkt Revo intercooler since 3 years but this time on hot summer i see IATs above 50c all the time and on full WOT it doesnt go below 45c. Ambient temp is mostly 30-34c these days. Should i check the intercooler and charge/throttle pipes if there's oiling inside? i usually run map1 or map6 and peak boost is 16psi on 97 RON fuel.
What is your test scenario? Keep these facts in mind:
1. IAT readings will be higher at light cruise conditions because even though the IC has constant airflow and may be cool, the throttle plate is mostly closed and the intake manifold where the temp sensor is, isn't getting much air flow.
2. Larger intercoolers don't heat soak as quickly, but once they do heatsoak, they take a while to cool off. Do not test temps after you've sat in hot traffic for a while.
