The car looks happy on those settings.
With that said, you should play around a bit. I think you may be able to turn it up from 3500-5000. Plug in 17 in that range and see what happens. Can't see what your 3000 RPM settings are. I think the IS12's fun range is 2500 to 4500.
Start your pulls below 3k.
EDIT: Also noticed you're blending fuels. You can easily store two (or more) Map 6 settings if you're using BT and a phone. It takes seconds to recall the maps and hit save to make the setting active. I really wish BMS gave us more custom maps slots, but it's not too bad recalling maps. Unfortunately the different maps are stored on the phone, not the JB4.
EDIT PSA: You can make MAP 6 tune changes while not connected to the car for loading later.
1. Save your current map 6 in the app when connected to the car.
2. When not connected (at work, on the shitter, etc), open the app -> User Adjustment -> Load Config -> Load your saved map
3. Make changes you want.
4. Save using new name, or old.
5. When connected to car, load your new settings from the saved file, hit save.
6. Floor the go pedal and log.
Hi guys
Finally installed my AFR harness and went to Map 2 and 6, so just wanted throw a log up for feedback. pretty sure it looks good tho. This thing makes me smile now.
Bone stock Canadian 2018 GSW 4mo- 50/50 Costco 91 and Petro-Can Ultra 94
using TwinDad's stock car settings, FOL-60, ambient temp around 6* C
https://datazap.me/u/alex-howard/log-1551023302?log=1&data=1-4-14-27
